One Of The Last - Back To A BX
   / One Of The Last - Back To A BX #51
QUOTE=TripleR;3818378]Glad it's working out so well for you, I am a big fan of the BX and also love the Hodge links.[/QUOTE]Those new sway links really show the need for some paint on your tractor:laughing:[ I don't know why a tractor mfg. can put something like that on a $15K-20k tractor rather than those el cheapo turnbuckles which don't work worth a flip even when new.
   / One Of The Last - Back To A BX #52
Gary FowlerThose new sway links really show the need for some paint on your tractor[/B]:laughing:
Ain't that the truth, that's what happens when you sell a tractor to someone who doesn't own a shed. We got it back a couple of years ago and it now lives under a roof in the barn.
   / One Of The Last - Back To A BX #53
I put the Hodge's stabilisers on my L3400. I noticed the implement rubbing on a tire, so I wanted a positive location, I bought a set from Hodge. Really good build quality, works great.
   / One Of The Last - Back To A BX #54
Those Hodge stabilizers look just like the adjustable Kubota factory installed standard stabilizers that are on larger L series- I first enjoyed them on my L3130, and would hate to go back to messing with turnbuckles!
   / One Of The Last - Back To A BX #55
My old John Deere had this threaded length adjuster, attached by a swinging pin.
So to tighten it up, remove the stabilizer pin, turn the adjuster a couple of turns, push the implement all the way to one side, and while holding it there with your shoulder, try to attach the stabilizer pin into the swinging pin on the tractor.
Then do the same on the other side.
Crud, its still too loose.
Do. Again.
Crud, its to tight now, and the pin won't engage.
Do. Over. This time loosening instead of tightening.
And you never, ever manage to do this on a nice day.
So given all of this, I was looking forward to using the Kubota turn buckle system.
However I realized that I was having enough problems getting my 5ft, 480lb boxblade horsed into the correct position in 2dimensions to engage the 3point. Getting a bigger and heavier boxblade lined up exactly by hand was just not going to be possible. So this time I'm investing in a guick hitch system.
2014 CATERPILLAR TL943C TELESCOPIC FORKLIFT (A51242)
2014 CATERPILLAR...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2014 Ford Explorer SUV (A50324)
2014 Ford Explorer...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A52128)
2014 Dodge Ram...
2019 PRINOTH PANTHER T14R CRAWLER (A51242)
2019 PRINOTH...
2019 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2019 UTILITY VS2RA...
