Boondox
Elite Member
- Joined
- Apr 6, 2000
- Messages
- 3,874
- Location
- Craftsbury Common, Vermont
- Tractor
- Deere 4044R cab, Kubota KX-121-3S
Ugh! I took this afternoon off to replace a failed 50 year old sump pump in the basement before spring thaw floods it. Of course the old pump was two wires no ground, and everything these days is grounded. So I installed a GFCI outlet and ran nomex all the way back to the circuit breaker box. Needed a 15A breaker so went to the hardware store. They didn't have any. WTF? So I went to the other hardware store. They only had the el cheapo slimline breakers - nothing I could use. WTF?!?
Okay, so I'll check the stores in Waterbury at work tomorrow as this is rural VT and everything is closed at 5pm. Except the bars catering to the skiers coming off the mountain. Holy cow what an aggressive bunch of drivers! 55 in a 35 zone, each one riding the bumper of the car in front, no quarter given to anyone trying to make a turn. Jeezum I'll be glad when the snow is gone!
So back home and down in the basement. I remove the old completely rusted out pump and the PVC line up to the main drain. Plug the opening to the main drain so sewer gas doesn't kill us all overnight. Spend the next hour removing debris and the remnants of the rotted wooden box the pump used to be housed in. The dirt sides started collapsing, so I scooped out a larger sump, then lined it with bricks. The bottom was grit which does not play well with pump impellers, so out into the meadow to kick around in the snow looking for that pile of slate I left there last summer. The dogs thought it was great fun digging in the snow with Dad.
Find the pile. Rummage thru it till I find a nicely sized slab. Trudge back to the house and level the slate in the bottom of the sump. Put the pump on top. It fits nicely. Reach for the check valve and find it's the wrong size for the pump. Crap! Hardware stores closed. Something else to pick up tomorrow.
Time for a beer.
Time for a beer.
