One More Bolt to Check/Tighten on your Kioti
   / One More Bolt to Check/Tighten on your Kioti #31
My post 27 has the part numbers you need for the lower 3pt link arm pin and bolt/flange assembly
   / One More Bolt to Check/Tighten on your Kioti #32
42 T4240-28533 PIN, LWR LINK RH $13.37
43 01774-51016 BOLT, FLANGE $1.40
Error
James,
Our posts crossed in the ether...
My dealer had one, $21 though...
I used the original link to find the correct part, talked to the sales guy and he had it in hand.
I'm gonna buy the longer bolt and lock washer at Lowe's...
   / One More Bolt to Check/Tighten on your Kioti #33
I picked up an M10 1.25 20mm, lock washer, and blue locktite yesterday at lowes.
Tractor will be back in service maybe today (depends on how my chores shake out today).
Thank you all!
Be well,
David
   / One More Bolt to Check/Tighten on your Kioti #34
Be advised that bolts come in several grades (typically, 5, 8, and 12). This link shows how their strength varies. You should try to match the stock bolts.
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56436)
Case Wheels for...
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A56435)
1995 Ford F-250...
2018 International WorkStar 7500 T/A Aquatech B-15 Combination Sewer Jetter Vacuum Truck (A56858)
2018 International...
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
UNUSED FUTURE FT20 EXCAVATOR (A52706)
UNUSED FUTURE FT20...
2015 FORD F-250 SUPER DUTY (A58214)
2015 FORD F-250...
