One More Bolt to Check/Tighten on your Kioti
   / One More Bolt to Check/Tighten on your Kioti #21
I'll go 'ya one better. Put a loop in a piece of Mason's line and slide it to the top collar on the pin, then tie the other end to the hairclip pin. Insert pin through drawbar and then put hairpin in place. If/when hairpin gets snagged then it will hang down and not be lost, in most cases.
I would think a drawbar for one's specific tractor, or even a generic one would not be hard to match up for a reasonable price, in most instances. Even a used one from a tractor yard?
   / One More Bolt to Check/Tighten on your Kioti #22
Been there, done that on these same pins (both sides) backing out due to the bolts coming loose. I added locktite the last time, but I'm thinkin' it will do it again.
   / One More Bolt to Check/Tighten on your Kioti #23
Anyone know the part number for the pin? I lost one on Sunday bush-hogging and while I'm sure it is in that field, not sure I can find it...
My dealer has taken 3 days and has yet to call me back.
I need my tractor!
Thanks in advance,
David
   / One More Bolt to Check/Tighten on your Kioti #24
Part # Description Price Qty
T2445-29781 JOINT PIN $10.67 2
70515-16334 PIN, SNAP $3.29 2
   / One More Bolt to Check/Tighten on your Kioti #25
James,
Which piece is the snap?
Enclosed are the pics of the missing part...
Good to see you sir!
Be well,
David
   / One More Bolt to Check/Tighten on your Kioti #26
David the part numbers I posted are the pin that holds the drawbar in and the "hairpin" clip which you can buy at any tractor supply store.. it looks like you have a different problem with the lower links being disconnected. go to Michigan Iron and equipment web site and look for what you need. I would stay and help, but I have to go to work..
Error
   / One More Bolt to Check/Tighten on your Kioti #27
42 T4240-28533 PIN, LWR LINK RH $13.37
43 01774-51016 BOLT, FLANGE $1.40
Error
   / One More Bolt to Check/Tighten on your Kioti #28
Click on the link anyway, even if it says error
   / One More Bolt to Check/Tighten on your Kioti #29
James,
I lost the pin for the base of the 3-pt arm.
Not for the draw bar.
Sorry I was not more specific.
David
   / One More Bolt to Check/Tighten on your Kioti #30
From what I can tell from your pics you need the type of pin held in by a bolt that is adjacent to the pin and fits in an oblong shaped metal housing.
Best call Tony at MIE, their number is located in the parts schematic KOua linked for you. I can't believe your local dealer would take 3 days to get back to you. I would ask Tony to ship it to you if they have it and then locktight it in place. It MIGHT be the same pin assy as is used in the FEL arm assy. If Tony can confirm this you could temporarily remove you loader and 'steal' the assembly until you get a replacement.
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A56435)
2016 RAM 5500...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Landoll Lowboy Trailer (A56435)
Landoll Lowboy...
GMC 2500HD 4wd Service Truck (A56435)
GMC 2500HD 4wd...
Kubota L3130 (A53317)
2013 ISUZU NPR STAKE BODY TRUCK (A58017)
2013 ISUZU NPR...
