One little Clean BX22! :)
/ One little Clean BX22! :)
the deck is still laying against the garage wall & I need to clean it better. I just removed it a few days ago and sharpened the blades. I will polish the painted surfaces and I spray the bottom with silicone. After cleaning, I grease then clean fittings. The deck is very clean now since I did not mow that much this year since I put a new front lawn in. Also going to install some synthetic gear oil in the box.
/ One little Clean BX22! :) #22
What brand and weight are you going to use in the gear box? I figured that now is the time to get all this done since there is not much more that can be done on the seat till it snows. /forums/images/graemlins/grin.gif
I am just using 75w-90 from Amsoil Series 2000 but there are other gear lubes that are also good. Redline is good. You can also use an SAE 80 or 80w-90 since they are close enough for a mower deck.
It will not even take a qt of fluid. I would add it to my front diff but that is already done.
/ One little Clean BX22! :) #24
Underneath I hit it pretty hard with the washer. Paint was gone the first year anyway. On top I use the soft nozzle to just get the clummps of grass off and the grease. I first spray it with degreaser then rinse off.
murph
/ One little Clean BX22! :) #25
</font><font color="blue" class="small">( </font><font color="blueclass=small">( ....a nice clean storage shed that is heated.
murph )</font>
How do you heat it? Gerard )</font>
Gerard,
This storage shed is part of my house. Lower level of a rambler, but I have double swing doors going into it from outside. My mechanical equipment is in there also so it stays pretty warm.
murph
/ One little Clean BX22! :) #26
</font><font color="blue" class="small">( What brand and weight are you going to use in the gear box? )</font> <font color="blue"> </font> /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gifJust pluckin away ehh???
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
2019 FREIGHTLINER M2 4X2 S/A NON 26FT NON CDL BOX TRUCK (A59914)
2019 FREIGHTLINER...
40' Used Container, High Cube, Single End Doors  (A62679)
40' Used...
3pt 7' Cultivator (A64127)
3pt 7' Cultivator...
2022 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2022 FREIGHTLINER...
2023 VOLVO L90H WHEEL LOADER (A65053)
2023 VOLVO L90H...
