One brake axle OK??
/ One brake axle OK?? #41
<font color="blue"> I like the Jordan, it is porportional braking, you will have trailer brakes even if the tow vehicle doesn't. It also shows amperage draw from the magnets to show if all your brakes are really working. </font>
All of the above also applies to the Prodigy.
/ One brake axle OK?? #42
</font><font color="blue" class="small">( <font color="blue"> I like the Jordan, it is porportional braking, you will have trailer brakes even if the tow vehicle doesn't. It also shows amperage draw from the magnets to show if all your brakes are really working. </font>
All of the above also applies to the Prodigy. )</font>
Really??
Before I point out a few differences I just want ya to know I don't currently own either Prodigy or Jordan since selling my 3500 in Oct. I have a Draw-Tite in my Pete for pullin my 16' utility trailer which is just for stabilizing the trailer and not necessary to help stopping the Pete.
Ok now on to a few differences, I will go with the proportional braking if the TV brakes are working other than that they are different.
Prodigy is inertia, so if the TV brakes ever fail ( god forbid)you won't have trailer brakes till you find that little button on the controller in a now panic situation.
Jordan uses a cable attached to the brake pedal so the farther you push pedal the more braking.
Prodigy will show voltage or a shorted magnet or no connection with certain display readings.
Jordan shows amperage draw on correct working brakes and a certain amt depending on how many magnets are in the circuit and as we all know amperage shows work and voltage shows what's available.
The prodigy is easier to install than the Jordan and lots of folks like easy.
Both are good controllers but they are not created equal.
2009 Cummins DGFA-5764071 150kW Standby Diesel Generator (A61572)
2009 Cummins...
We do NOT accept credit cards as payment. (A64119)
We do NOT accept...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2015 Ram 1500 Pickup Truck (A61573)
2015 Ram 1500...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A61572)
2025 HT360W Mini...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
