3-Point Hitch one arm of 3 point lift will not lift
   / one arm of 3 point lift will not lift #1
JRF
South Carolina
Hello, I have a Kubota B7500HST. left side arm (looking from back) on 3 point lift will not lift. Hydraulics goes up and down correctly only left arm stays down.
Everything is attached. Nothing slipped off. Any ideas what it might be. Where do I start looking?
Thanks.
   / one arm of 3 point lift will not lift #2
Lift arms are not independent... lift arms are raised together. Something broke. 050 in the parts above? or stripped out grooves.
   / one arm of 3 point lift will not lift #3
Ouch, thats gonna cost some money to fix. I agree, sounds like something broke internally.
I agree with #50 too... its a place to start anyway.
   / one arm of 3 point lift will not lift #4
On the side that doesn't move with hydraulics, you should be able to pick it up by your hand. Does it rotate around the shaft? or does the shaft and arm move together?
   / one arm of 3 point lift will not lift #5
Broken shaft or stripped arm end. Should be an easily removed cover plate that will open up the housing.
Thought I posted this reply yesterday.
Thanks everyone. Lift arm is stripped. Shaft splines seem to be in good shape.
Thanks for the replies.
CAT E70B Excavator (A51573)
CAT E70B Excavator...
2121 (A51244)
2121 (A51244)
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
2004 IH 5600l Snow Plow Truck (A52384)
2004 IH 5600l Snow...
2007 International 7400 Chassis Truck, VIN # 1HTWGAAR87J437650 (A51572)
2007 International...
2022 CASE 580 SUPER N BACKHOE (A51246)
2022 CASE 580...
