3-Point Hitch one arm of 3 point lift will not lift
   / one arm of 3 point lift will not lift #1
JRF
South Carolina
Hello, I have a Kubota B7500HST. left side arm (looking from back) on 3 point lift will not lift. Hydraulics goes up and down correctly only left arm stays down.
Everything is attached. Nothing slipped off. Any ideas what it might be. Where do I start looking?
Thanks.
   / one arm of 3 point lift will not lift #2
Lift arms are not independent... lift arms are raised together. Something broke. 050 in the parts above? or stripped out grooves.
   / one arm of 3 point lift will not lift #3
Ouch, thats gonna cost some money to fix. I agree, sounds like something broke internally.
I agree with #50 too... its a place to start anyway.
   / one arm of 3 point lift will not lift #4
On the side that doesn't move with hydraulics, you should be able to pick it up by your hand. Does it rotate around the shaft? or does the shaft and arm move together?
   / one arm of 3 point lift will not lift #5
Broken shaft or stripped arm end. Should be an easily removed cover plate that will open up the housing.
Thought I posted this reply yesterday.
Thanks everyone. Lift arm is stripped. Shaft splines seem to be in good shape.
Thanks for the replies.
2014 Ford Escape (A50323)
2014 Ford Escape...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
RoGator RG1100C (A52748)
RoGator RG1100C...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
