Onan twin cylinder engine electronic ignition
   / Onan twin cylinder engine electronic ignition #1
60lp
Bronze Member
Friendsville Tennessee
1020 john Deere,300B Deere backhoe,773G turbo Bobcat,LT30 Woodmizer sawmill with 2-cylinder air cooled diesel Engine
I'm trying to find electronic ignition for my Air Products model AP 200MG 6.OCCK-331E/5289L serial 0470209494 120 volt single phase 3.5KW @100% Duty Cycle 60 Cycle @ 1800 RPM I hope I give enough information all will be very appreciated also I'm needing a carburetor build kit also thanks again
   / Onan twin cylinder engine electronic ignition #2
Ignore the fact that you have a generator or welder or whatever, and just go for the parts for the engine. I've found some Cummins/Onan resources online; head in that direction.
   / Onan twin cylinder engine electronic ignition #3
   / Onan twin cylinder engine electronic ignition #4
A generic Pertronic kit. Aluminum collar with a pellet magnet is slid onto the crank and held with an Allen key grub screw. Fasten the detection/switching module to clear the collar by 20 thou. Connect the Pertronix to a dual output coil with a matching primary winding. There are Pertronix for 3.0okm could and a Pertronix II for coils with resistance down to 0.3 or 0.5ohms range .
2013 F-550 Bucket Truck (A53472)
2013 F-550 Bucket...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
KUBOTA MX4700D TRACTOR (A51247)
KUBOTA MX4700D...
2015 FORD F350 SERVICE / MECHANICS TRUCK (A52576)
2015 FORD F350...
28013 (A50322)
28013 (A50322)
