JD420
- Joined
- Oct 23, 2012
- Messages
- 40
Hello everyone. I was hoping someone could give me so advice on how to remove the camshaft out of a onan b48g. After mowing yesterday I noticed the engine sounded as if it had a rod knocking but on further inspection the noise is coming from the back of the engine by the flywheel. After pulling the motor off and removing the timing cover I found a large amount of play in the rear cam bearing. Almost enough to allow it to skip time. Upon trying to remove the cam it slides out approx 3/4 inch and stops. I've removed the points and the push rod for them and also the lifters. But it still won't come out of the engine block. Sounds as if its hitting something. I didn't know if I had to remove the crank first or what was going on. Any advice would be greatly appreciated. Thanks in advance nick.
