Generator Onan 25kw Generator
/ Onan 25kw Generator #12
I think a BX model is a little light for it. I see on northern tool supply a 27KW PTO generator for tractors of 48HP and up.
/ Onan 25kw Generator #13
I have Generac PTO 25 and a Ford 1720 with 23 pto hp and my tractor runs it fine and powers the whole house including the 5500 watt dryer, well, fridge, freezer & any other device at the same time.
As was said the KW produced is dependent on the pto hp of your tractor which in your case will be 8 to 10 kw.
The flywheel effect will also help with surge from larger loads such as deep well pumps, & other motors.
This will be a great back-up and you will be able to power the whole house with little or no restrictions on electrical load.
tim
/ Onan 25kw Generator #14
I found a steal of a deal. One 25kw Onan PTO generator for a dollar. It is an older model but if it works it is definitely worth travelling the 700km to pick it up. My question is, I have a 23hp BX25 Kubota and would like to know if I can run this generator at ~ 10kw with my machine without any problems:confused:. Thanks in advance for your valuable input. :thumbsup:
If it can be fixed up at a low enough cost it would be a bargain. I wouldn't over think this too long or someone else will have it. Free items like this will go fast.
/ Onan 25kw Generator #15
When you guys are connecting these units to earth grounded circuits are you making a earth ground at the generator?
I'm probably starting a war here, but a buddy I grew up with was electrocuted by a PTO generator that went hot through the tractor and I have called these things widow makers ever since.
/ Onan 25kw Generator #17
You are correct it needs to be grounded to the house ground to prevent electrocution and proper operation and protection of the house electrical system.
There should be a ground lug on the generator frame for this purpose. I attached a 20 ft heavy guage ground cable and clamp to mine for grounding purposes.
Tim
24017 (A56859)
24017 (A56859)
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A61307)
Snap-On Gold Medal...
2016 GMC Seirra Denali 1500 4x4 Crew Cab Pickup Truck (A60352)
2016 GMC Seirra...
AGROTK YC-32G Horizontal Band Saw (A60463)
AGROTK YC-32G...
2012 HEIL (A60736)
2012 HEIL (A60736)
207283 (A52708)
207283 (A52708)
