On pto lever wicth way is 540 up or down
   / On pto lever wicth way is 540 up or down #1
robert holter
staticmap
   / On pto lever wicth way is 540 up or down #2
why the map? is that where you live, you mightnot want to post that??
Anyway on my ym2000 its all the way down but not for sure on the American models?
   / On pto lever wicth way is 540 up or down #3
Judging by that map Id have to say down also.
   / On pto lever wicth way is 540 up or down #4
Looks like going West on Riverview will get you back home from the spot you marked on your other map. And as Clemson and CarDoc already said, South (down) a little too.
As for your tractor pto lever - both my US Yanmars are 540rpm Down, 1000 Up. Do you have a Yanmar too?
Anyhow - we're just funnin you. Welcome! :drink:
   / On pto lever wicth way is 540 up or down #5
robert, on my Yanmar 2200 I have 2 levers that are associated with the PTO speeds. There are 4 speeds on mine. I'd have to go look to see what position would be 540. Are you sure yours has only 1 lever for the PTO?
Others chime in to say if theirs are 1 lever or 2.
   / On pto lever wicth way is 540 up or down #6
I need to correct my previous post.
I used the PTO on the YM186D recently and its 540 was Down.
But I went and looked at the YM240. its 540 is UP.
In any case - both are US-version Yanmars, and their two PTO speeds are 540 and 1000. Each tractor has one PTO lever with neutral at the center position.
I hope we didn't scare off our new friend. I see he hasn't logged in since starting this thread eleven days ago. Robert, are you still here?
   / On pto lever wicth way is 540 up or down #7
My 2002d has 3 speeds, 550 down, up one knotch is neautral, 1 more up is 2nd (784), 1 more up is 3rd (1096). All at 2400 engine speed. 1 lever.
   / On pto lever wicth way is 540 up or down #8
540 is left and down on mine I have 1 stick 4 gears in an H pattern and fwtw my tach has the speeds and gears marked right on it for reference. hth And yes we were just kidding around the map and all I couldn't resist sorry. :)
   / On pto lever wicth way is 540 up or down #9
Ym2000 is the same as winston described.
   / On pto lever wicth way is 540 up or down #10
I must have the oddball then, 2 sticks and you change position of both sticks to get different speeds. Glad the decal is still on it or I'd be lost.
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
2012 JOHN DEERE 410K BACKHOE (A51406)
2012 JOHN DEERE...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2022 BOBCAT T64 R-SERIES SKID STEER (A51246)
2022 BOBCAT T64...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
