? on LP heater
/ ? on LP heater #11
Smaller tanks around here are filled by the pound. Typical Bar-b-que tank, 20 lbs. Larger tanks for heating uses 100 lb. Any idea on the conversions between Pounds, Therms, BTUs and Gallons?
/ ? on LP heater #12
We have had a ventless in the basement for three years and have not had any moisture problem. Does anyone know what causes it(moisture problem). It is used in conjunction to our heat pump and we go through roughly about 200 gals per year.
___________________________________________________
Take care, Jim
2001 B7500 HST 302 Fel R4 Tires, Befco BRB60
Semper Fidelis
/ ? on LP heater #13
PaulT, according to my little Operator's Manual for Safe Dispensing of Propane, provided by Ferrellgas, "When the propane liquid is changed into a gas, it will occupy about 270 times the volume as the liquid."
Bird
/ ? on LP heater #14
DocHeb, maybe I can provide partial answers. Of course, if you just figure 4 pounds per gallon, you'll be close enough. Have you ever looked at the data plate, or information, on those propane cylinders? I've never understood why people come up with "specialized" terminology instead of using plain English, but the data plate (actually not a plate, but stamped on the cylinder or collar) lists the tare weight (T.W.) of the empty cylinder (empty weight, in other words). Then it lists the water capacity (W.C.) in pounds - don't ask me why - who's ever going to put water in it? So you can multiply the water capacity by 0.42 and determine the propane capacity. Next you can add the propane capacity weight and the tare weight and know what a properly filled cylinder will weigh.
Propane is supposedly 91,547 BTUs per gallon (compared to approx. 120,000 BTUs for gasoline) and, in its vapor state, approximately 2,516 BTUs per cubic foot (compared to 1,040 for natural gas).
And I don't know anything about Therms.
Bird
/ ? on LP heater #15
Bird,
<font color=blue>Propane is supposedly 91,547 BTUs per gallon </font color=blue>
You seem to have a flair for the right words/w3tcompact/icons/smile.gif In this case "supposedly " is the exact right word. As an example the U.S. Department of Energy identifies 84,000 BTU's per gallon. The real number is a pressure/temperature (primarily temperature) dependent number. This is the reason why cylinders are not filled to capacity ~80%. The expansion with temperature is significant. In the good old days my propane bill was identified by "therms". Now it's gallons and the equivalancy to heat value (therms) is controlled by requlation. The therm is pretty much transparent to the end user.
Al
/ ? on LP heater #16
Paul,
<font color=blue>Aren't liquids "generally" uncompressable. </font color=blue>
Pretty much so, but they do change volume with temperature. Top off your rig on a cold morning and park it in the sun all day and it may overflow. Propane tanks are only filled to about 80% to make room for liquid expansion.
Al
/ ? on LP heater #17
Or if you want to cheat you could move the decimal point over on the water column and be pretty darn close as well. Say for a 20 lb cyl is 47.2 ---move it over to the left and you have 4.7 gallons of propane at 100% full. Actually its 4.2 gallons for a tewnty lb cyl (at 80%) but it gets you in the ball park and it's easy to remember. /w3tcompact/icons/smile.gif
Tare wt and the size of cyl is the proper way to fill a dot tank. As you well know. But that stamed label does say alot if you know how to read it on bot a D.O.T. tank and an A.M.S.E. tank as well. Shame they can't put it in english so we all could understand it.
Gordon
/ ? on LP heater #18
The byproducts of complete combustion are carbon dioxide and water. Your heat pump is probably dehumidifing the air.
/ ? on LP heater #19
Brad,
Thanks, I forgot to mention we also have a dehunidifier in the basement to. I could'nt figure out when winter camping my truck topper always had so much moisture in the morning. I use one of them vent free little buddy heaters. Now I guess I need to find something else.
____________________________________________________
Take care, Jim
Semper Fidelis
/ ? on LP heater #20
What would you guys suggest for a heater for a 15x36 that's fully insulated and needs to be kept at 40 degrees or above all winter?
<P ID="edit"><FONT SIZE=-1>Edited by cowboydoc on 10/02/01 07:59 AM (server time).</FONT></P>
KJ K2223 23'x22' Metal Shed (A60463)
KJ K2223 23'x22'...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2023 Kubota L2501 (A60462)
2023 Kubota L2501...
2007 MACK CHN613 DAY CAB (A59906)
2007 MACK CHN613...
CFG QK16R (A60463)
CFG QK16R (A60463)
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
