Oliver 770 Roosa master Stanadyne pump removal question
   / Oliver 770 Roosa master Stanadyne pump removal question #1
stevewatr
Massachusetts
Ford 1920 2WD geared
Hello, I am having trouble removing the gear from the pump drive shaft. I was able to remove the pump because the whole gear/shaft assemblly slid out the front, but I know during re-assemblly, in order to be sure the umbrella seals go in correctly, I think I need to insert the shaft into the pump first, then install the pump, but because the tractor gear does not fit through that hole on the back, I think it has to come off. There were two bolts going through holes in the gear, they appear to help index the gear to the shaft, then there is a large nut on the end of the shaft, but it will not budge. The only way to hold the shaft, is by the tang on the end. I'm worried I might snap the shaft at the skinny part. Is there a trick to removing this nut??
A nice guy on Yesterday's tractors forum advised holding it with a rag, and useing an impact wrench.....It worked great.
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2018 CASE IH 110N LOT NUMBER 207 (A53084)
2018 CASE IH 110N...
Pallet of miscellaneous chains  (A52384)
Pallet of...
2012 Ford Explorer (A50123)
2012 Ford Explorer...
2013 WABASH DVCVHPC 53FT DRY VAN TRAILER (A53426)
2013 WABASH...
2015 John Deere 544K Articulated Wheel Loader (A52377)
2015 John Deere...
