Oliver 770 Roosa master Stanadyne pump removal question
   / Oliver 770 Roosa master Stanadyne pump removal question #1
stevewatr
Massachusetts
Ford 1920 2WD geared
Hello, I am having trouble removing the gear from the pump drive shaft. I was able to remove the pump because the whole gear/shaft assemblly slid out the front, but I know during re-assemblly, in order to be sure the umbrella seals go in correctly, I think I need to insert the shaft into the pump first, then install the pump, but because the tractor gear does not fit through that hole on the back, I think it has to come off. There were two bolts going through holes in the gear, they appear to help index the gear to the shaft, then there is a large nut on the end of the shaft, but it will not budge. The only way to hold the shaft, is by the tang on the end. I'm worried I might snap the shaft at the skinny part. Is there a trick to removing this nut??
A nice guy on Yesterday's tractors forum advised holding it with a rag, and useing an impact wrench.....It worked great.
2017 Ram 5500 Chassis Crew Cab Reading Service Truck (A52377)
2017 Ram 5500...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
Unused 2025 Wolverine SBM-12-72W Sickle Bar Mower Skid Steer Attachment (A51691)
Unused 2025...
