Oliver 1365 / White 1370 Rod bearings
   / Oliver 1365 / White 1370 Rod bearings #1
crazyhorsemd
cincinnati, Ohio
2000 New Holland TN70, 1974 White 1370
HELP
In need of connecting rod bearings for Oliver 1365 / White 1370
Need .050 or .060 sizing
can find .040 but really need .050 and , or .060
OR would anyone know of comparable size replacement
any help appreciated
crazyhorsemd
   / Oliver 1365 / White 1370 Rod bearings #2
If you can't find them, maybe you could put shims behind the .040 shells. Seems like it would work if you locktite them in place. Maybe a crazy idea, I don't know.
where would you find shims for this. never heard of rod bearing shims is this something your could purchase at specific thicknesses??
   / Oliver 1365 / White 1370 Rod bearings #4
You would just buy shim stock and cut it with scissors or tin snips. I did it once with a piece of aluminum foil in back of a motorcycle rod bearing, but that's very thin. Seems like it would work for you as long as it stays in there.
   / Oliver 1365 / White 1370 Rod bearings #5
Never thouht off that ! With the bearingshell lip sticking out a lot it must work. A 0.05 shimstock will give you that 0.1 you need .
(INOP) FORD 2000 TRACTOR (A51247)
(INOP) FORD 2000...
10' CONTAINER (A51248)
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
2019 KUBOTA U35-4 EXCAVATOR (A51246)
2019 KUBOTA U35-4...
UNUSED CFG QK16R EXCAVATOR (A51247)
UNUSED CFG QK16R...
2023 JACTO ARBUS-1000 LOT IDENTIFIER 66 (A53084)
2023 JACTO...
