Ole Country Boy from South East Tx
   / Ole Country Boy from South East Tx #1
DGrassSr
Two 4110 4x4 Mahindra
Need a little help from the tractor experts,I have a 4110 4X4 Mahindra 49 Hp about 7 yrs old.Front in loader want lift up and down like it use to,here is what i have done so far.
Last year took of both front cylinders replaced with all new O rings.worker great until this last cold spell we had?(I sure don't mind working on the old thing) The bucket works great tilting it back and forth ,my brush hog works good just used it no problem with it working up and down.I change to Hyd fluid and all filters three months age.I did raise the bucket and bled the lines to the front cylinders( no air in the lines)and no leaks any where else i can see.
I was trying to dig a hole to bury a goat that just died and was having trouble lifting the bucket.Sometimes it works a little and then it just want lift up at all.
I just jointed the group so maybe some one out there might can help this ole country boy,Thanks, See Ya...
   / Ole Country Boy from South East Tx #2
Welcome to TBN. :)
Hello Myfriends:
No answer from anyone so i went to work on it,took off the front left cylinder first. Took it all apart and there was a broke Oring on the first part of the piston.Thought, that couldn't be that easy,put it all back together and Whammm.works just great,so you never know.Thanks anyway guy's,See Ya.
   / Ole Country Boy from South East Tx #4
Glad to have you join us. Of course your posts are here in the New Member Introductions forum and probably weren't seen by the members who might have had an answer for you. For that, you need to post your questions in the Mahindra forum. Anyway, glad you got it fixed. And now you may be able to help the next person with a similar problem.
2014 Ford Escape (A50323)
2014 Ford Escape...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
Year: 2012 Make: Honda Model: Accord Vehicle Type: Passenger Car Mileage: 91,438 Plate: Body Type... (A51694)
Year: 2012 Make...
NEW 78'' Wolverine Skid Steer Land Leveler (A53002)
NEW 78'' Wolverine...
1998 INTERNATIONAL 9400 (A52472)
1998 INTERNATIONAL...
