Oldest Power-Trac
/ Oldest Power-Trac #11
Thanks for the pics J J. What kind of repair work have you had to do to it over the years.
/ Oldest Power-Trac
I think it is about 10 years old. The folks that had it before me took good care of it. The only trouble I had with it was a starting problem which I finally found. The leads on back of the neutral switch were shorted together. Intermittently I may add. I guess It could have took off if the treadle was not centered.
PT says they don't have much info on this model, or they just don't want people to know. The have to know what engine they put in their machines. /forums/images/graemlins/confused.gif Some one told me it was a Ford industral 4 cyl. Runs great. I have no idea what the model number is.
Can you believe it's 75 degrees here in Jacksonville, Fl ? /forums/images/graemlins/grin.gif
/ Oldest Power-Trac #13
Yeah, it's in the mid-40s here and raining. Very mild winter so far except for a short cold snap a couple weeks ago.
/ Oldest Power-Trac
No big repairs so far. I did rebuild the three cyl up front, and my tilt arm froze to the 2 in pin. I cut it out and welded a new set on. I am in the process of building a backhoe that mounts on the front, and a grapple for the hoe.
/ Oldest Power-Trac #15
That is good service J J. I'll be looking forward to seeing that back hoe.
2000 Vermeer TC4A Walk-Behind Trench Compactor (A59228)
2000 Vermeer TC4A...
2025 SKLP SK-PSJ220 Electric Jaw Crusher (A59228)
2025 SKLP...
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
2025 Hydraulic Stump Grinder Mini Skid Steer Attachment (A59228)
2025 Hydraulic...
2016 Kenworth T800 Tri-Axle Dump Truck (A59230)
2016 Kenworth T800...
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
