Older sprayer used for Roundup
   / Older sprayer used for Roundup #1
pigdoc
Ames, IA
JD 2025R, Kubota ZD28
I've got an ATV sprayer that I used a few years ago (7+) for round-up'ing the fence lines at my horse farm. Now the horse farm is sold, and I need a sprayer to apply herbicide to my 1.5 acre lawn. Can I use the old sprayer that was used for Roundup? Is there a way to clean the Roundup residue out? Or, do I need to get a new sprayer? thanks in advance.
Pigdoc
   / Older sprayer used for Roundup #3
   / Older sprayer used for Roundup #4
nutra-sol will neutralize stuff like hy-dep, but ive been told that all the rubber gaskets need to be replaced if round up was used.
Personally, i think if you were to run 8-10 loads of clean water thru it, it should be neutralized and Diluted enough. you can always test it on a small area and wait a few days to see what happens.
   / Older sprayer used for Roundup #5
You don't need a new sprayer, think about all the custom spraying outfits and farmers going from one herbicide to the next. Usually it's just a triple rinse through the pump and nozzles and it's clean enough for the next batch.
   / Older sprayer used for Roundup #6
Roundup can be used as a grass growth retarder at ultra-low rate, so hopefully the worst you'll do is ****** the growth.
1999 LinkBelt HTC8650 50 Ton Crane Boom Truck (A53117)
1999 LinkBelt...
Leeboy 685 Grader (A47477)
Leeboy 685 Grader...
2015 Hyundai Veloster Hatchback (A53424)
2015 Hyundai...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A53424)
2 windsor 351...
Adams Tender / Magnolia Trailer (A53473)
Adams Tender /...
