Older John Deere tractor info
   / Older John Deere tractor info #1
Rowski
North Central Vermont, Jay Peak Area
2004 New Holland TN70DA with 32LC loader, 2000 New Holland 2120 with Curtis cab, 7309 loader
Our local town highway department has a yellow John Deere model # jd301a. Its 2wd. They say its John Deere commercial. Basically I (they) need to know the specs to decide if they want by some attachments for it. I tried one site that I have book marked for tractor info but it didn't list it.
   / Older John Deere tractor info #2
Find the serial number on the machine and go to a good John Deere dealer they should be able to help you.
Ken /forums/images/graemlins/smile.gif
   / Older John Deere tractor info #3
Go to the deere forum on ytmag.com and ask them to tell you what the ag version of this tractor is, post the highway department model number and someone can probably tell you the equivalent ag.
   / Older John Deere tractor info #4
Are you sure it's a 301a? I never heard of that model with JD. JD had the old A tractors but that's not something you would want for a work tractor. That's more of an antique tractor.
   / Older John Deere tractor info #5
Do you think it is a 310A? That is a popular JD industrial model.
   / Older John Deere tractor info #6
Yes i know the tractor it's an updated 300,very good machines the 301 would have been late 70's ealy 80's. 3cyl. i think at that time only offerd in diesel. I can't remember hp but it's around 40-50 pto hp witch is how tractors used to be rated. witch in my opinion was beter than gross eng. because the trans. type and no. off gears pto drives ect. can change pto hp. greatly,most tractors do some kind of pto dutyies. Anyway i hope the hp info will help you with the implement choice.
   / Older John Deere tractor info #7
I just noticed your in VT. if you need exact specs. you could call Nortrax here in pembroke N.H. im sure someone there will know exact info,it was a popular tractor for road matanence moeing,loader work, and a small hoe was avalible.
I was told by the road commissioner that its says on the hood jd-301a. I have seen the tractor many times before while it is working. They have a mid mount sickle bar mower and a 3pt hitch pto broom.
It looks like or very similar to this..
   / Older John Deere tractor info #10
The 301A Deere was made from '74-81. It used a 152 cubic-inch, three cylinder diesel. It had 43 PTO hp.
FYI - 301A Gasoline units were made from '74-79. Same horsepower...different engine displacement.
2017 Dodge Caravan Van (A50324)
2017 Dodge Caravan...
2017 Chevrolet Malibu 1LT Sedan (A51694)
2017 Chevrolet...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
2001 Ford F150 (A50121)
2001 Ford F150...
2007 FORD F-450 SUPER DUTY (A52472)
2007 FORD F-450...
