Older Case 580K hydraulic primary pump leaking
/ Older Case 580K hydraulic primary pump leaking #1
Denbaranch
new holland TC40D
Today while digging out a oak tree stump, my hydraulic system started leaking fluid like a rain storm while using my older Case 580K Backhoe. When moving the backhoe to level ground my steering became difficult. My guess is I blew a main seal OR ??
I dont have a manual, so where do I Start. First I will get under the old gal and see if I can detect where the leak orginated.. all suggestions and hel is appreciated.
/ Older Case 580K hydraulic primary pump leaking #2
There's a hydraulic hose, a large one that goes from the pump to the steel line on the left side of the frame. Most likely it dry rotted and burst. Don't run the engine as you will destroy your hydraulic pump if it doesn't have oil! That hose has to be the exact same length as the old one (even 1/4" too long or short will not work). It's not too hard to get at but be prepared for plenty more oil to leak out (assuming you didn't loose it all). Because it's larger than normal you may have a problem finding the correct fittings if you go to an automotive parts store to have a new hose made up. My suggestion would be a place that deals with large equipment.
2022 CATERPILLAR 299D3 XE SKID STEER (A64279)
2022 CATERPILLAR...
2002 Bobcat 863 Compact Wheel Loader Skid Steer (A61572)
2002 Bobcat 863...
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
Lot 602 (A62613)
Lot 602 (A62613)
2025 Hydraulic Brush Cutter Skid Steer Attachment (A61572)
2025 Hydraulic...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
