Oil & Fuel Older 4 lug b7100dt kubota oil question
   / Older 4 lug b7100dt kubota oil question #1
robby26wi
Whats the best for the transmission-hydraulics? It says 80wt but that seems very heavy...Thanks
   / Older 4 lug b7100dt kubota oil question #2
If your in cold country the Kubota SUDT is recommended and UDT for everything else. There are other brands out there that will work just fine like Mystik.
so what is that if i dont want to use kubota fluids?
   / Older 4 lug b7100dt kubota oil question #4
I use UDT in mine - the local tractor place sells it - but they also sell "Universal" Tractor Fluid. This is the equivalent they tell me. On the drum it had viscosity 5W20. Which seems about right. The price differential was minimal, so I bought a drum of Kubota UDT. 80 weight oil gets used in the front axle and steering box. The gear box oil also does the hydraulics, so I can't see 80 weight oil being the right answer...
Cold conditions aren't an issue where I live :rolleyes:
Cheers!
2001 Ford Explorer SUV (A56859)
2001 Ford Explorer...
2287 (A58376)
2287 (A58376)
JCT 72" Skid Steer Rotary Brush Cutter Attachment, Asset# 68 (A59076)
JCT 72" Skid Steer...
Hydraulic Thumb Clamp (A57149)
Hydraulic Thumb...
(1) HD 20ft Free Standing Corral Panel with Feed Bunk (A57453)
(1) HD 20ft Free...
Unused IRTPL 10,000lb Two Post Car Lift (A55272)
Unused IRTPL...
