Oil & Fuel Older 4 lug b7100dt kubota oil question
   / Older 4 lug b7100dt kubota oil question #1
robby26wi
Whats the best for the transmission-hydraulics? It says 80wt but that seems very heavy...Thanks
   / Older 4 lug b7100dt kubota oil question #2
If your in cold country the Kubota SUDT is recommended and UDT for everything else. There are other brands out there that will work just fine like Mystik.
so what is that if i dont want to use kubota fluids?
   / Older 4 lug b7100dt kubota oil question #4
I use UDT in mine - the local tractor place sells it - but they also sell "Universal" Tractor Fluid. This is the equivalent they tell me. On the drum it had viscosity 5W20. Which seems about right. The price differential was minimal, so I bought a drum of Kubota UDT. 80 weight oil gets used in the front axle and steering box. The gear box oil also does the hydraulics, so I can't see 80 weight oil being the right answer...
Cold conditions aren't an issue where I live :rolleyes:
Cheers!
New Valley Pioneer SCL850 Mini Skidloader (A50774)
New Valley Pioneer...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
UNUSED FUTURE FT-E48 ELECTRIC BICYCLE (A51244)
UNUSED FUTURE...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
2017 Ford F-250 Ext. Cab Pickup Truck (A50323)
2017 Ford F-250...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2020 Ram 1500 4x4...
