Older 300 Suzuki King Quad
   / Older 300 Suzuki King Quad #1
Grayson Klassen
Fort St John, BC
John Deere 4020
I bought an older 300 King quad from a guy. He said he had just done the rings and some other work. Anyway as soon as the thing warms up it starts smoking horribly. It almost instantaneous from no smoke to lots. Kind of a gretish stinky smoke.
Anyone had one with a similar problem or know what it might be?
   / Older 300 Suzuki King Quad #2
Sounds like transmission oil is getting into the engine, probably a bad seal.
   / Older 300 Suzuki King Quad #3
I believe on that model the transmission an engine crankcase use the same oil.
It could be burning oil due to the new rings not seating into the cylinder or the ring end gaps could all be lined up allowing oil a free path into the combustion chamber. Another possibility is a bad head gasket or leaky valve guides.
Whenever someone tears down a motor, many variables are added to the list of potential causes.
Makes ense. Curious as to why just when iy heats up. Maybe I should try to retorque the head and see if it helps otherwise I am guessing valve guides seal as well
   / Older 300 Suzuki King Quad #5
my FIL has the same problem with his Quad runner. His started after being over heated. I have heard the same issues with the rings, and was hoping to pull it apart in the next week or two.
Hope you find something simple
Good luck
1999 Ford RV , VIN # 3FCMF53S2XJA29020 (A51572)
1999 Ford RV , VIN...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2020 Mitsubishi Fuso FEC7TS Cab and Chassis Truck, VIN # 4UZBVH115LGLFU342 (A51572)
2020 Mitsubishi...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
2020 RoGator RG1300 Air Max Precision R2 Spreader (A53342)
2020 RoGator...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
