Old Wells - Part II
/ Old Wells - Part II #21
Fill it with broken concrete blocks and broken cement...Many construction outfits will deliver that sort of debris for free...Once its semi-full cover with a few feet of dirt and plan on adding dirt over then net couple of years...:D
/ Old Wells - Part II #22
hudr said:
quote: <Just throw all your trash junk and refuse in it and quit paying a garbage bill.
When you get about 2 feet from the top buy enough fill dirt with the money you saved on the trash bill and fill it on up.>
:0
I wonder how many neighbors' wells have been ruined by this train of thought?
Groundwater doesn't abide by property lines.
Probably more than you can count on both hands.
SnowRidge said:
Just fill it with water and throw some carp in. :D
Carp? Did you spell that wrong? If so, building an outhouse over it would not be a bad idea!:D
If you did mean carp, then maybe up that a little and put some giant goldfish in it and call it a coy pond!:p
/ Old Wells - Part II #24
:D :D :D :D :D
You just made my morning. I'm laughing so hard, I can hardly type.
/ Old Wells - Part II #25
broken block and brick sounds like a good idea. I agree you could probably get a truck load for next too nothing
/ Old Wells - Part II #26
I know you can or know somebody who did ever which way you want to look at it.
I put a bunch of busted up concrete [from an old side walk] down by the road and put a free sign on it.
It filled up the pick up of the guy who took it.
/ Old Wells - Part II #27
That's pretty scary looking.
Here in Michigan we have laws about plugging abandoned wells, which is primarily to prevent groundwater contamination. Might see what applies in your state. Contaminated groundwater is bad for everyone, and extremely difficult to fix. I would look at filling the well with CLEAN sand and rocks if the law doesn't require something else. I would be strongly inclined to fill the well and not just re-cap it. Concrete rubble wouldn't be the worst, but it probably won't be totally CLEAN and I'm not sure how all the lime in it might or might not affect the groundwater. Clean sand would be my #1 choice, plus whatever rocks you have lying around or can get cheaper than sand.
/ Old Wells - Part II #28
Z-Michigan said:
That's pretty scary looking.~~~~~~~~~~Here in Michigan we have laws about plugging abandoned wells, which is primarily to prevent groundwater contamination. .
Accidental death or injury is another primary reason to fill abandoned wells.
/ Old Wells - Part II #30
N80,
First of all its time for you to drop the N80 and go get the D300. :D:D:D:D:D Then change your TBN name. :D:D:D
My FIL is retired from the DOT. Years ago when looking for land to buy we find a property with an open, uncovered hand dug well. Very scary. The FIL said that DOT required the well to be filled with concrete!
Last spring it cost me $75 per hour to run a dump truck that could bring in 15-16 tons. He was running ABC aka road base for me which I think cost around $10 per ton so say $225-250 per load if the truck can round trip in one hour.
That material and load works out to around 5 yards per truck load.
If you start asking dump truck owners, excavating companies, feed/farm stores, you might be able to find some dirt for little or no cost. The dirt we put on our yard after the house was built was free. Had to pay for the truck but the dirt was free.
How you get the fill to the well is another issue. :D
Later,
Dan
Noooooo way I'm saying anything to the state or county.
I agree with you about ground water, but this thing is only 35 feet. My regular well is something like 280 feet. Anyway, if I do fill it, it won't be with anything that would hurt the ground water. At only 35 feet, dumping it in there won't be a whole lot different from dumping it on the ground in regard to water contamination.
dmccarty said:
N80,
Well, I've got a D200!:D The N80 was my first serious camera and the 'username' just stuck! (And I'm too lazy to change it and the D200 might be my last camera....as long as it lasts anyway. (I love it and have no need to upgrade.)
I will keep looking for someone with a load of some time of 'dirt' or rubble. They could drop it near by and I could fill with the FEL. Which will be fun!
/ Old Wells - Part II #33
I understand on not contacting govt. But you can usually look up info like this in the library or on the web without having to identify yourself or explain why you're looking it up.
Many areas have multiple aquifers (note: my father is a hydrogeologist; I have a BS in geography with an emphasis on physicial geog.). I don't know what your geology is but I wouldn't be surprised if your 280ft well is in a different aquifer than the surface water. Anyway, I agree that anything that you would reasonably dump on the ground is probably not going to matter much in a 35ft well, just avoid "trash" like someone suggested, and obviously avoid dumping in the 35ft well anything with liquid/gaseous petroleum products, soluble heavy metals, salts, etc. in it.
/ Old Wells - Part II #34
Hi George and the Gang,
Just pondering about your old homesite, (what a wonderful place), some more. In later years, do you think the owners of the old house ever put in a septic tank?
The reason I ask that is...on my property an old house was in a different location than the newer house I am living in now. Messing around one day, (planting azaleas), I found the old septic tank. It is still in good condition.
Probing around, you might find one nearby, who knows? If so, with your tractor you could dig it up and use the free septic tank for your own cabin and uses... Of course you would put in the drainfield, etc. but at very little cost.
Just a thought...
2008 KENWORTH T300 FLATBED FUEL TRANSPORT TRUCK (A58214)
2008 KENWORTH T300...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
MULTIQUIP LIGHT TOWER (A60736)
MULTIQUIP LIGHT...
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
Informational Lot - Financing (A61307)
Informational Lot...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A60352)
2019 Allmand...
