Oil & Fuel old water pump
   / old water pump #1
razafas
Romania
UTB u445/m650
This is a bit off topic since is not about a tractor, but a water pump ; A 16 hp. 2 stroke gasoline engine from 1987 (never used, and dirt cheap). The thing is that i don't know how gasoline used to be 29 years ago, i know it used to be lower octane and more viscus; and in order to somewhat mimic this i added more 2T mixing oil (50mL per 1 liter), but the engine seams to be running hotter (burned thru the head gasket seal) and the spark plug gets dirty fast.
Anyone have solution for this ?
   / old water pump #2
Not an expert on gasoline from the Ceaușescu era, but I think you would have been better off just running regular old gasoline and not second guessing things.
   / old water pump #3
You are WAY overthinking this. Just put some 87 in it. My tractors from the 50's does not care. My 2c leafblower form 91 does not care and my 2c snowmobile from 72 does not care. Adding oil beyond 50/1is just going to foul the plugs like you are seeing. Running hot may be a carb or cooling issue. (plugged fins)
   / old water pump #4
That's a 20:1 mixture. That should be fine in an '87 (or any 2 stroke for that matter, jetted accordingly). The owner's manual recommendations should help a bit.
Think about this: when you put more oil in the fuel you are increasing the oil/fuel ratio but decreasing the fuel/air ratio. This leans the mixture and generally leads to hotter running.
What do you mean by "burned thru the head gasket seal"? Sounds like a wreck to me...
   / old water pump #6
2 stroke = no valves or valve seats to wear out ... so leaded or non leaded is fine...
just follow the specs for 2 stroke oil for the engine ....
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
1994 Mack CH613...
Case 580 Backhoe Loader (A50514)
Case 580 Backhoe...
John Deere 7210 (A50120)
John Deere 7210...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A52748)
Koyker Loader...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
