Old trucks can still tow! My numbers
   / Old trucks can still tow! My numbers #11
'02 is not old, '74 was a good year...
   / Old trucks can still tow! My numbers #12
   / Old trucks can still tow! My numbers #13
That's so foreign to me; as long as you're under 10k you can run passenger plates all day, over that you need 'commercial' plates. I basically have passenger plates on my F350, and it's totally cool so long as I don't go over 10k pounds GCWR. I can only speak for Maine, though.
Ironically, at 11400 lb GVWR, I can't actually max load my truck. Not that I realistically could anyhow, as it's just some retirees daily driver.
When I got my ck3500 I took it to class 4A. At class 3 with 3 people technically overweight and figured if ever stopped with trailer I would be better off with higher class. What a waste of money. Now it’s farm plated
   / Old trucks can still tow! My numbers #14
Pennsylvania. As with most truck registrations yi have ever delt with you choose the registered weight at or below the GVW of the vehicle which translates to different costs depending on the weight class. Just that you truck is capable of a certain weight capacity doesn't mean you will use it so just register it as less and save on registration.
Another PA driver here. Yeah, every 1/2 ton I've ever owned gets that "Class 2" weight sticker on the windshield. Registration costs a few bucks more, but not so much as to make it worth dickering around with registering at a lower class.
I believe our "Class 1" limit is only 5000 lb. gross, and with the curb weight on most pickups being around 4600 lb. (since at least 1990's), it'd be awful difficult to use one under 5000 lb. Hell, two passengers and a full tank of gas would put you over the class 1 limit!
I thought these vehicle classes were national, didn't realize it was a PA thing.
   / Old trucks can still tow! My numbers #15
The only problem I have had in 20 years was at the quarry when I wanted a ton of aggregate but they only gave me about 500 lbs due to my registered weight.
What a nice guys at your quarry. When i picked up gardening topsoil for my fathers flower bed, the loader operator had a big grin on his face to see the scale run up to 5960kg, with my old Volvo S70 TDI. Not that that diesel really cared as it took off by just slowly releasing the clutch without revving up first, but i was quite illegal. Add my father, myself and my nephew and we would be 6150kg or 13.600 pounds.
   / Old trucks can still tow! My numbers #16
I am just surprised...I was under the impression that a new 2024 Silverado would be so far ahead rating wise compared to my 22 year old WT. The current entry level 2024 Silverado (which mine was when purchased) with the four banger is only rated at 9500lbs max towing so things have actually been downgraded when comparing new apples to old apples.
....and then there's the other end of the equation.... I had a 2014 GMC rated to tow ~9800lbs max I believe. Over the 7 years it was in my possession I used it for towing several times a year and on occasion up around the max rating in combination with a 10K trailer. Always handled fine for my relatively limited needs. Truly I enjoyed the truck and its capabilities. The problem was that it ate two transmissions while I owned it, and then ate a third after I sold it to my mechanic when the AFM system started acting up and required about $5K worth of repairs.
   / Old trucks can still tow! My numbers #17
Even 1/2 tons you guys have to rate for towing? I complain about Michigan laws but I guess I will stop doing that.
   / Old trucks can still tow! My numbers #18
5000 lb. is limit for class 1 vehicles. Again, I always thought this was a national thing, not a PA thing. I guess I wouldn't know, since every vehicle I've ever owned has been registered in PA.
Not a big deal, the dealership slaps a "Class 2" sticker in the windshield at time of purchase, and it stays there until you sell the truck. Registration is a few dollars more, but not enough that I'm really worried about it.
   / Old trucks can still tow! My numbers #19
Pennsylvania. As with most truck registrations yi have ever delt with you choose the registered weight at or below the GVW of the vehicle which translates to different costs depending on the weight class. Just that you truck is capable of a certain weight capacity doesn't mean you will use it so just register it as less and save on registration. Sometime with medium/ heavy trucks you need to derate them which means removing a spring or changing tires. There is risk in commercial truck category to get in trouble if your weight is over registered but for a small pickup 1/2 or 3/4 ton you don't really need to worry unless you are grossly overloaded. The only problem I have had in 20 years was at the quarry when I wanted a ton of aggregate but they only gave me about 500 lbs due to my registered weight.
Wow. I never heard of registration options by GVW. Everywhere I’ve lived, they charge registration by private or commercial use and by truck category: 1/2, 3/4, 1 ton, ect…
   / Old trucks can still tow! My numbers #20
Here in TN they have regular passenger vehicle tags for $29 a year that are good for up to 8,000 pounds. They rarely if ever harass people for towing boats or campers with those tags even though they’re over 8,000 pounds. Then they have J tags that are for agriculture and personal use which you can buy between 8,000 and 80,000 pounds. They have H tags for commercial use that cost about 4x what the J tags cost for the same weight. You can buy whatever tag you want to pay for any vehicle. You can put an 80,000 pound tag on a ford ranger if you want to. Of course you can’t haul 80,000 with a ford ranger but if you want to pay the money for the tag nobody is stopping you. You can put a 16,000 pound tag on a semi tractor and drive it empty if you want to. Troopers largely don’t care about towing capacity from what I’ve seen. They do care about axel weight. Unlike towing capacity axel capacity is clearly stamped on the vehicle and trailer and easy to check. You’ll overload the rear axle on non dually pickups faster than most people realize.
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
Deere 331G (A53317)
Deere 331G (A53317)
CASE 610 Sprayer System 2000 Gallons (A55315)
CASE 610 Sprayer...
2012 Ford F-550 Crew Cab Truck (A54814)
2012 Ford F-550...
2016 KENWORTH T680 SLEEPER (A57880)
2016 KENWORTH T680...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
