Old troy built tiller questions
   / Old troy built tiller questions #11
POR 15 makes a kit to repair motorcycle fuel tanks.......a bit pricey but the stuff does get rid of rust, coats the inside of the tank, and fixes small holes.......YES, I have tried it on my 1975 BMW R90, and for me was totally worth the money and effort......Dennis
   / Old troy built tiller questions #12
will a harbor freight predator 212 7 horse replace my 6 horse tecumsie engine on my 1977 6 horse tiller
   / Old troy built tiller questions #13
.my name is charles t smith i need to know if a harbor freight 212 cc 7 horsepower horizontal shaft motor wall replace my 1977 tecumseh horizontal shaft original motor on my 6 hp 1977 horse model rototiller
   / Old troy built tiller questions #14
If you download the product manual from harbor freight, the last page, and it's really hard to see, shows the bolt pattern being 3.625" or 3 5/8" which would be the same as the 6hp tecumseh. The shaft appears to be 3/4" in diameter and 2 7/16" long with the 3/16" keyway. I would call Harbor Freight customer service to confirm and also confirm what you have.
Good Luck
   / Old troy built tiller questions #15
I think you will be fine with that little 5 horse BS; it may a little lite on power but certainly usable. 2manyrocks got it right - the older Troy builts had a 6hp tecumseh engine. Cheers! :)
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
S/N: 1240824 (A55853)
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
Bucket (A55973)
Bucket (A55973)
TEST YOUR BID BUTTON! (A52708)
TEST YOUR BID...
Yamaha (A55758)
Yamaha (A55758)
