Rustyiron
Super Member
I've got an old Troy Bilt Horse and have decided that it deserves a good servicing. I bought it, used from an estate, prolly 12 or better years ago. I have only used it literally 3 or 4 times because I usually use the tractor tiller.
Well now I have scaled down the garden size and want to take care of the 'ol girl, I've only ever changed the engine oil. I drained the gearbox oil and figured that it takes 90 wt. ( I don't have a manual) but what drained out looks like maybe 140 wt. gear oil. It's prolly not that critical, just hate to do things wrong if I can avoid it. The second thing is the rear housing for the tiller drive (shaft) and gearbox, I don't see a drain anywhere. It has the 1/2" sq filler plug with an attached dipstick (it reads full) but for another quart or so I'd have ALL new oil(s) in the whole unit. Do I loosen the 2 bolts that attach it io the rest of the machine and just turn it up to drain? I was woried that if I did that I might booger up a gasket or seal between the 2 parts and I really don't want to chase down any more parts. It is (I think) pretty old, the S/N is hand stamped into the casting and on the casting that supports the handles, Garden Way is cast into it. Thanks for any help.
