Old sears GT 18HP garden tractor carb/fuel pump question
   / Old sears GT 18HP garden tractor carb/fuel pump question #1
powerscol
SW Colorado
CT 235
OK I am playing around with my 25+year old 18HP garden tractor. It not getting fuel to the carb. Will run fine if I dribble gas through the carb. I had also used a small can of fuel with hose attached to gravity feed and carb works fine. I did this to see if pluse fuel pump would pump, but no go. I replaced the pulse fuel pump, but just cant get it to pump fuel.
I was think of just getting a small electric fuel pump, but figured I would need a pressure regulator. New hoses all around too. Fuel is good to new pump.
Thoughts on a simple fix.
Thanks
   / Old sears GT 18HP garden tractor carb/fuel pump question #2
The old hose may have collapsed internally preventing fuel from getting from the tank to the carb. Or a big gob of junk is in the bottoms of the tank.
When you pull the old hose off the carb does it flow?
Yes if I hold it low enough. But I will check again. I was going to pull the tank anyway and clean it out, just in case there is junk where I cant see. However I do get good flow through the can filter that is 1 foot off the tank.
2025 IR UNUSED Hydraulic Thumb (A53117)
2025 IR UNUSED...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A53473)
Michelin CARGOXBIB...
PALLET OF MISC PUMPS (A51248)
PALLET OF MISC...
JOHN DEERE 560M LOT IDENTIFIER 138 (A53084)
JOHN DEERE 560M...
UNUSED WOLVERINE TQH-26-02C CLASS II 3 PT HITCH (A51248)
UNUSED WOLVERINE...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
