Old sears GT 18HP garden tractor carb/fuel pump question
   / Old sears GT 18HP garden tractor carb/fuel pump question #1
powerscol
Veteran Member
SW Colorado
CT 235
OK I am playing around with my 25+year old 18HP garden tractor. It not getting fuel to the carb. Will run fine if I dribble gas through the carb. I had also used a small can of fuel with hose attached to gravity feed and carb works fine. I did this to see if pluse fuel pump would pump, but no go. I replaced the pulse fuel pump, but just cant get it to pump fuel.
I was think of just getting a small electric fuel pump, but figured I would need a pressure regulator. New hoses all around too. Fuel is good to new pump.
Thoughts on a simple fix.
   / Old sears GT 18HP garden tractor carb/fuel pump question #2
The old hose may have collapsed internally preventing fuel from getting from the tank to the carb. Or a big gob of junk is in the bottoms of the tank.
When you pull the old hose off the carb does it flow?
Yes if I hold it low enough. But I will check again. I was going to pull the tank anyway and clean it out, just in case there is junk where I cant see. However I do get good flow through the can filter that is 1 foot off the tank.
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A53472)
Adams FL24...
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
(2) UNUSED 3500# IDLER AXLES (A51247)
(2) UNUSED 3500#...
UNUSED PAIR OF FUTURE 7" RUBBER TRACKS (A51248)
UNUSED PAIR OF...
Tradewinds Power Unit (A50120)
Tradewinds Power...
2017 Snapper Pro 48in Zero Turn Commercial Mower (A51691)
2017 Snapper Pro...
