"Old School" JD's... (eg, JD750, etc)
   / "Old School" JD's... (eg, JD750, etc) #11
You are correct that the 50 series are old school as far as CUT's are concerned. The 850 and 950 were the first compact models JD introduced. 1978 I believe. The 650 and 750 followed shortly afterward and the 1050 was last. (1250 and 1450 were about the same time, but they are a little large to be considered CUT's) And yes, the 50 series were all built by yanmar for John Deere. All great tractors. Have seen a few with over 10,000 hours and still going strong.
I have a JD650 with 1275 HRs on it. It is 4 speed gear box and two speed Hi - Lo selection. It came used with a #67 loader and I built a small 3pt. backhoe attachment. Built very heavy duty. The only thing I'd wish for was a little more HP and hydrostatic, other than that I love its simplicity and it looks like a "real" tractor.
   / "Old School" JD's... (eg, JD750, etc) #12
I have a 86' JD950, purchased used, with original FEL and BH. At 970hrs it is going strong. I went used over new for the usual reason of price. I have not been disappointed with that decision having had great service out of this machine with very few maintenance expenses. Having run much larger farm tractors for years I was apprehensive about the capabilities of a CUT. The 950 has set my mind at ease in that regard at every opportunity. The only complaint I do have is the stabilizer arms on the BH are not built rugged enough. From the looks of the newer models this has been corrected. Good luck with your search.
Mini Excavator (A55787)
Mini Excavator...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
Plastic Bear Statue (A55853)
Plastic Bear...
2020 Bobcat T550 Compact Track Loader Skid Steer (A55851)
2020 Bobcat T550...
2014 Ford F-150 Pickup Truck (A53422)
2014 Ford F-150...
