Old question, new scenario, 72" vs 60" deck
   / Old question, new scenario, 72" vs 60" deck #1
jives
Wheel Horse 416-8
Hi folks:
Long time member, minimal contributor. This question has been asked a million times before, but each scenario is different, and I'm looking for folks who have been there and can say they made the right decision, or the wrong one.
Essentially, given the scenario outlined below, would you choose a nimble tractor with a 60" mower, or a less nimble tractor with a 72" deck? I've chosen the Kubota forum because it is really only Kubota and Deere that offer reasonable used choices here.
Here is the situation. About 2.2 acres mowed and cared for with a couple of Wheel Horse garden tractors. Driveway plowing, garden tilling (not recently), cart pulling, etc. This is the left side of the property below. Mostly open, but you can see the trees and obstacles. Takes about 3 hrs mowing, mostly because the grass is so lush that I cannot mow in 3rd gear. 3.3 mph in 2nd gear with my tired Wheel Horse 416-8. Mostly flat, some wet spots, slight grade from lower left of picture to upper right. Raised septic leach field and separate drain field to mow over. These fields are not deep, in fact, grass won't grow over the distribution boxes because they are so shallow. I don't drive the tires over the d-boxes.
We want to open up the undeveloped side of the property, about 4 ac. This will be after cutting and killing the invading buckthorn trees (greener looking brush on lower right side of photo). Most of this is by hand (cordless Makita recip saw with pruning blade - best tool ever!), and after that is done it will need to be mowed regularly to keep the buckthorn and other invasive plants at bay. The first couple of mows will likely be a guy (or gal) with a brush hog, but after that, we'll finish mow it. Pretty rutted, many gopher holes, hasn't been farmed in 15-20 years. Eventually, we will be mowing the 4 ac with a finish mower 2 times a month for 7 months of the year. We also hope to eventually prep the soil -- disking, seeding, planting at least a cover crop. Will need to do some land leveling. We are experimenting with other options, from growing a forest to a wildflower meadow.
Other needs will be a loader, 3 pt hitch capacity for a box blade and other implements, and so forth.
So, here is the question. A subcompact, like a Kubota BX with a 60" MMM will handle the 2.2 ac finish mowing sufficiently, but how well can it handle the chores of the 4 ac? Is it too small to work efficiently? On the other hand, a small compact, like a Kubota B (got my eyes on a B7800) with a 72" MMM should be just the ticket for the 4 ac, but it it too cumbersome for the 2.2 ac?
No fair saying that a zero turn plus a tractor is the best option. One tractor only.
Thanks.
   / Old question, new scenario, 72" vs 60" deck #2
.............................No fair saying that a zero turn plus a tractor is the best option. One tractor only.
Thanks.
That's not fair, because that is exactly what I would get.
Used B7800 size or similar tractor with front loader and flail mower and also used front mount Diesel mower, Kubota F or similar JD / Grasshopper.
   / Old question, new scenario, 72" vs 60" deck #3
Don't be shy! The larger deck on the larger B model will not be as nimble as a BX but the larger deck will help!
   / Old question, new scenario, 72" vs 60" deck #4
Sidetrack,,, what program do you use for your aerial pic? I like the distance markings on the boundaries a lot!!!!
Google maps, satellite image. . .then shift and left mouse click to get a menu with the "Measure Distance" tool. Coolest tool ever! If you are on a Mac it may be different commands. Anyway, then shift with right mouse click to get to a screenshot command. Save the screenshot as an image, and viola!
   / Old question, new scenario, 72" vs 60" deck #6
Thanks!!!! I really like that feature. Didn't know it existed. As is the case with a lot of today's technology!!!! :D
It is indeed not fair that life is not fair! On the other hand, I do have in the back of my mind a used front mower. A couple of used JD F mowers and Toro Groundsmasters on CL now, and they could be an interim fix.
   / Old question, new scenario, 72" vs 60" deck #8
Pick whatever deck you want because you’re already limiting yourself to the inferior options. My 72” zero turn mows grass TWICE as fast as a 60” MMM. Compared against a Kubota B7200 and a 455 John Deere.
   / Old question, new scenario, 72" vs 60" deck #9
Re: Old question, new scenario, 72" vs 60" deck
Oohh, that was a bit mean. Especially since his last sentence was one tractor only.
So you guys are suggesting that it be a zero turn front mounted mower machine??
   / Old question, new scenario, 72" vs 60" deck #10
I don't have a ton of experience with tractors so I don't feel competent to make a judgement on what machines to recommend to you. However, in reading your original question, it appears that you may be open to the possibility of using part of the acreage for a more natural area for pollinators and wildlife. You don't indicate your location but I am assuming you get some cold months due to the fact you only expect to mow 7 months of the year. I have some fields at my place in Maine that used to be used for haying. Now, I leave those fields to wild flowers like goldenrod and milkweed. I bush hog the fields once a year after the wild flowers have died for the year. Cutting once a year keeps the trees and bushes from getting a start but provides forage for pollinators like bumble and honey bees, monarch butterflies, etc. that we need so badly. Cutting once a year would greatly reduce the number of hours needed on an annual basis for field maintenance and might allow you to get a smaller, less expensive machine. Personally, I think we should rethink the idea of having such huge expanses of perfectly manicured lawns. It may look nice but it is time and resource consuming and provides no usable habitat for the insects and animals that share this Earth with us.
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
2005 Cheverolet 2500 Pick Up Truck (A59814)
2005 Cheverolet...
JLG 1255 Telehandler (A56438)
JLG 1255...
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
S/A Fuel Tank Trailer (A59231)
S/A Fuel Tank...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
