Posthole Digger Old Posthole Digger Questions??
   / Old Posthole Digger Questions??
You are probably correct. I assumed the smaller diameter bolts would be the ones to shear. The bolt through the gearbox input shaft measures 7/16". If that one shears, what prevents the PTO shaft from spinning wildly out of control?
Do you suppose there something else attaching the two shafts? I didn't notice another bolt -- but I have been, so far, unable to separate the drive shaft, assuming the two are rusted together. Guess I better take a closer look!
   / Old Posthole Digger Questions?? #12
On most phd the pto shaft will have a small set screw that fits in a groove on the input shaft. This keep the shaft from falling off the input shaft when the shear bolt breaks.
   / Old Posthole Digger Questions?? #13
Yep, the set screw rides in a groove on the input shaft so if the shear bolt does shear, it keeps that end of the PTO shaft from coming off and wreaking havoc.
If you watch the video of PHD assembly on EverythingAttachments.com, Ted will show you the set screw on the PTO shaft.
I double checked and find no set screw securing the drive shaft. View the first 10-12 seconds of this clip and let me know what you think. I still can not remove the PTO shaft from the gearbox. I removed the "shear bolt" through the middle.
http://db.tt/kavbZPAc
   / Old Posthole Digger Questions?? #15
I think it's time for some good penetrating oil and let it soak in for a little while. If that don't work it may take some heat to break it loose.
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
John Deere 3025E (A53317)
John Deere 3025E...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
Forklift (A59228)
Forklift (A59228)
