Old plows with available wear parts?
   / Old plows with available wear parts? #1
blucoondawg
Pelican Lake, WI
Kioti DK50SE w/ loader and Woods 90x backhoe, Allis Chalmers C with front snowplow
I'm considering picking up a 2 bottom plow when I come across something worth while, I've got a kioti dk50se.
I'm sure this has been discussed somewhere in the forums but I haven't seen it, can anyone tell me what brands of the older stuff still has availability for new wear parts, the huge majority of plows I see here are Dearborn plows with the occasional Oliver or a little newer Ford but those are much more rare. Currently there are 2 Dearborn 10-1 in the area online, one looks like the shares are good but one of the moldboards looks to have an issue where someone welded a brace across the back, she wants 550 bucks for that which I believe is quite high, the other one has the tips broken off both shares and he wants 150 for that one, is the 10-1 a plow that parts can be found easily, what brands and models of plows are still serviceable?
   / Old plows with available wear parts? #2
   / Old plows with available wear parts? #3
I’ve restored several plows. Both were old Ford plows, and I had no trouble finding parts. The old Deere plows would also be good. One warning, make sure you buy a plow with some sort of trip mechanism, either shear bolts or spring trip. When you hit a rock or root, the plow will trip, and nothing will be bent or broken. My first plow had no trip protection, and I destroyed it after two uses. IMG_4903.JPG
   / Old plows with available wear parts? #4
I bought a slightly used International World Agritech two bottom plow in the Spring.
Tried it Friday, sheared the “shear bolt”. Replaced with what I had and have plowed a few furrows.
Still learning but its good.
The Ford plow looks great OP>
   / Old plows with available wear parts? #5
Prices vary by region, but about 5 years ago I picked up a single bottom Ford 101 plow with new point and coulter for $300. At the time it looked as if it had never been outdoors, even the paint was pristine.
378810 (A51572)
378810 (A51572)
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
2011 GMC Sierra 4x4 Pickup Truck, VIN # 3GTP2WE36BG213306 (A51572)
2011 GMC Sierra...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
2009 Kubota KX080-3 Mini Excavator (A51573)
2009 Kubota...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
