Old Plow
/ Old Plow #1
Bendboater
Bend, Oregon
Kubota L2501
I have an old horse drawn, single bottom, plow that was my great grandfather's. It has been stored sheds/barns in multiple states for ..... decades but I have decided that I would rather have it out as "yard art" than let it lived such a sheltered life. It's in GREAT shape, though obviously well used. I have it blocked off the ground, under a tree, and away from irrigation. But I would still like to protect it (mainly the wood) as much as possible (it even still has some of the original red paint/stain on it). What would the collective wisdom of the group recommend I put on it to help preserve it?
Thanks.
/ Old Plow #5
I have seven of them that dad got at auctions & gave my wife over the years that are displayed.
I keep the metal painted and the wood soaked with linseed twice a year.
/ Old Plow
Topzide,
What is Black Star?
Sarg,
What color paint do you use on the metal?
/ Old Plow #7
All mine (wife's) are painted bright red.
/ Old Plow
Topzodi,
I like it. Do you think a quart of Black Star will cover the metal of a single bottom plow or would I be better off getting a gallon?
Ahh, the projects never end :)
/ Old Plow #10
I'd get the gallon. You'll find plenty of other items that need a coat. It gives a purplish-black finish without a top coating. (Which isn't needed) I coated the frame of my dually and after I did it a few years back, looked like a new frame! Cleans up easily and environmentally friendly!
/ Old Plow #12
Danish oil is a tougher oil than tung as it also has linseed and varnish mixed into the tung.
Withstands weather very well.
If the wood is bear, use 3 coats of either oil you get.
Waxed base oils are also very good for weather protection such as Osmo.
/ Old Plow
Thank you for the information. The Tung oil ihas already been ordered so I will be using that. I plan to thin it out and apply multiple coats until it stops soaking in. The plow will see more loving next week than it has seen in, probably a century. And, it will be appreciated rather than just collecting dust in my barn.
/ Old Plow #14
Nothing stopping you from coating it with other stuff such as Osmo or marine polyurethane after the tung oil.
I wouldn’t thin out the linseed oil on bare wood.
It’ll soak down deep enough to protect it on its own. If you thin it, you are sacrificing the protection quotient..
It may soak deeper into the wood thinned but it will have less capability of withstanding the surface elements. You need it strongest on the surface.
Three coats of the stuff are all you’ll need.
/ Old Plow #15
I am late but just for interest.
For the wood; Boiled linseed oil mixed with 1/3 varsol and stain applied several times a few weeks apart.
For the iron; rattle can rust restorative paint. Again two coats several weeks apart..
Dodge 5500 4x4 Altec Bucket Truck (A63689)
Dodge 5500 4x4...
2010 Chevrolet Tahoe SUV (A64194)
2010 Chevrolet...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
1985 Ford Ltl9000 Tender Truck (A63688)
1985 Ford Ltl9000...
1992 Rammax 7430 Trench Packer and Extra Set of Drums (A62613)
1992 Rammax 7430...
Case 580 Super E Backhoe Loader (A66285)
Case 580 Super E...
