old plow cat 1 pins too short to work with cat 2 hitch
   / old plow cat 1 pins too short to work with cat 2 hitch #1
Lowcountry Rebel
Ravenel S.C.
TYM 603
I bought an old double bottom plow with welded on cat 1 pins, started to attach it today for the first time and the cat 1 pins are too short for my cat 2 hitch- the retaining hole is partially hidden inside the hitch ball and I can't get a pin through.
I have an assortment of both sizes and use the sleeves to adjust.
I know I can cut/weld- or drill out the hole, but do they make an adapter that will pin on the cat 1 pin and allow me to connect my cat 2 hitch?
   / old plow cat 1 pins too short to work with cat 2 hitch #2
From your description I think your going to have to cut those off and weld new pins on
   / old plow cat 1 pins too short to work with cat 2 hitch #3
Agreed. Get longer Cat 1 pins at your local tractor dealer and after removing the short ones - weld on the new longer ones.
   / old plow cat 1 pins too short to work with cat 2 hitch #4
Never seen one and image search didn't find any.
One could be made, bored out to 7/8", that would slide over and pin to the cat 1 pin and go in the cat 2 socket.
   / old plow cat 1 pins too short to work with cat 2 hitch #5
Again I would just cut or remove old pins and install cat 2
   / old plow cat 1 pins too short to work with cat 2 hitch #6
Weld on a longer cat2 to cat 1 reducing sleeve with a hole drilled in it for the pin. No hole necessary if using quick hitch of course.
OR
Not ideal, but use the way it is with a smaller diameter lynch pin or grade 8 bolt if there’s enough room.
OR
Good Idea- thanks
2025 BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
2022 CATERPILLAR 301.5 EXCAVATOR (A52709)
2022 CATERPILLAR...
2020 INTERNATIONAL MV607 26FT CDL REQUIRED BOX TRUCK (A58017)
2020 INTERNATIONAL...
Scrap Water Tank, Asset# 61 (HAS HOLES) (A59076)
Scrap Water Tank...
