Old news New news
   / Old news New news #1
tnaz
Gainesville, FL. GATOR COUNTRY
Is everyones tractor running so good that there is no news, good or bad???
I never post cause it's hard for me, words don't come easy. My 3820 is running great;hope this doesn't jinks me.
Still looking for a backhoe, any info always welcome.
Thanks tnaz
   / Old news New news #2
This board sure is slow. I guess that is a good thing.
I bought a new close out Jinma Hoe on ebay and modified the sub frame to fit my 3510. I'm very happy with it. I run the throttle about 1400 RPM and it has good power. It's easy to forget that it's not a real hoe then I snag a root and it won't pick up. But when it's just dirt I can see how much power it does have and it picks up just fine.
   / Old news New news #3
I'm still working mine no problems! Splitting wood, droping trees, chipping limbs, grading property, pulling stumps. Vegtable garden coming this spring.
Bob
   / Old news New news #4
Mine is doing well. I operate it at about 2200 average. Used it yesterday to clean up some wooded area. I do notice that sometimes the front loader doesn't pick up as much as I THINK it use to, even though my RPMs are elevated. Any thoughts?
   / Old news New news
I would check the fluid level, make sure the vavle under the sit is open more than hafe way, if that doesn,t do it maybe filter change???
I anit no mo-canic.
Terry
   / Old news New news
YEA; I saw that; I don't think I am that far from you, I would like to see that sometime if you would not mind. I tried the branson 8620 hoe I believe and I liked it but not as much as Scott did. Not to say I want go back and get it???
My 3820 has done me well so far.
KNOCK on my head!!!
Terry
   / Old news New news #7
Mine's been running great, just gave it the once over for spring.. changed oil, cleaned air filter, etc. But now I noticed that my water temp gauge isn't registering - I wonder if that's just because it's running cool, or is the sender whacked out? Anyone know how to test the temp sender?
   / Old news New news #8
A single wire sending unit is usually a resistor afair that changes with temp. To check just ground the wire. It should read all the way hot or all the way cold.
   / Old news New news #9
Thanks! I'm going to ohm that sensor cold, then check it again hot. I'd rather it be a sensor problem than the gauge in the dash..
   / Old news New news #10
My 4720 anit seen much action lately either,
I did fire it up today to get to my Harley, both started and ran fine ;)
Anyone got a part # for a oil filter from auto store?
Gene
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53473)
2016 RAM 5500...
Broce KR350 (A50123)
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
2121 (A51244)
2121 (A51244)
1986 Wisconsin 24' Tilt Deck Trailer (A52384)
1986 Wisconsin 24'...
(INOP) FORD 7710 TRACTOR (A51247)
(INOP) FORD 7710...
