Old MF 50 hydraulics quit working
/ Old MF 50 hydraulics quit working #1
jjaaam
John Deere 1020
Hello,
I have a 1959 MF50 that has seen better days. Recently I was using the rear blade on my driveway and the three point lift quit working. The front loader doesn't work either.
If I actuate the valve I can see the three point move slightly but that's it.
I'm a tractor idiot so any ideas would help. I didn't pay that much for it so I'd hate to throw a ton of money at it.
Any ideas?
/ Old MF 50 hydraulics quit working #2
Sounds like you lost pressure. Start with the easy stuff. When did you last change the hydraulic oil and filter? I had similar symptoms and a change of the oil and filter resolved the problem. My filter was on the suction side so I assume the pump was starved. Next step would be to check the pressure from the pump with a gauge.
/ Old MF 50 hydraulics quit working #3
loosen a pressurepipe an see if theres flow....look at pumpcoupler....mybe stripped .
As I noted, I'm not very well versed on these. The oil was changed just within the last year. I have no idea about a filter. I've heard that some models have one and some do not. From my research if there IS a filter it is mounted to the pump that is located under the top cover of the 3-point below the seat, and that it isn't easily changed. So...if the filter needs to be changed then how do I do it without spending a $$$ to get someone to do it? Because if that's all it is then I'm home free.
iDrive TDS-2010H...
2016 Lincoln MKC SUV (A61569)
2016 Lincoln MKC...
JLG 460SJ TELESCOPIC BOOMLIFT (A62129)
JLG 460SJ...
LandHonor LHR-SB2T3M 2-Ton Chain Hoist (A60352)
LandHonor...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 International HX620 Quint Dump (A62613)
2018 International...
