Old MF 50 hydraulics quit working
/ Old MF 50 hydraulics quit working #1
jjaaam
Member
John Deere 1020
Hello,
I have a 1959 MF50 that has seen better days. Recently I was using the rear blade on my driveway and the three point lift quit working. The front loader doesn't work either.
If I actuate the valve I can see the three point move slightly but that's it.
I'm a tractor idiot so any ideas would help. I didn't pay that much for it so I'd hate to throw a ton of money at it.
Any ideas?
/ Old MF 50 hydraulics quit working #2
Sounds like you lost pressure. Start with the easy stuff. When did you last change the hydraulic oil and filter? I had similar symptoms and a change of the oil and filter resolved the problem. My filter was on the suction side so I assume the pump was starved. Next step would be to check the pressure from the pump with a gauge.
/ Old MF 50 hydraulics quit working #3
loosen a pressurepipe an see if theres flow....look at pumpcoupler....mybe stripped .
As I noted, I'm not very well versed on these. The oil was changed just within the last year. I have no idea about a filter. I've heard that some models have one and some do not. From my research if there IS a filter it is mounted to the pump that is located under the top cover of the 3-point below the seat, and that it isn't easily changed. So...if the filter needs to be changed then how do I do it without spending a $$$ to get someone to do it? Because if that's all it is then I'm home free.
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
master diesel generator (A64553)
master diesel...
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
2011 Ford E-350 Passenger Van (A64556)
2011 Ford E-350...
SKID STEER AUGER ATTACHMENT (A62613)
SKID STEER AUGER...
2006 International 4400 Horton Emergency Truck (A64556)
2006 International...
