Old McCULLOCH Needs Some Attention
/ Old McCULLOCH Needs Some Attention #1
AL_Josh
Mobile, Alabama
Cub LT 1046, 2000 Honda Rancher, 2004 Carolina Skiff
I was at my grandmother's house today and asked if I could get this saw to run. It was my grandfathers. It has sat in her shed for probly 15 to 20 years. It is a McCULLOCH PRO MAC 10-10.
I cleaned the spark plug and looked it over. I saw the fuel pick-up line had dried on it and I needed to get it out of the tank and after messing with it awhile I finally got it out. I then cleaned the tank out good and aded fuel. The line from the tank to the carb was still in decent shape. Anyway I got it to run and it ran like a top as long as I held the bar up and the fuel could get to the line.
So where can I buy a fuel line kit for it? I remember my grandfather replacing it when I was little. I have another saw but, I would like to get this running.
Also can anyone tell me anything about it? (Size Engine, Hp, anything like that) It appears to be a well built saw. I see no plastic on it except the chain brake.
Thanks to all,
Josh
Pic # 2
Pic #3
Sorry, Also How long of a bar could I use on it? I have a 16" on my cheapo saw. So I would like to use with a longer bar.
Thanks again,
Josh
/ Old McCULLOCH Needs Some Attention #5
Here's a link to a manual for sale on Ebay, the auction ends today but the price seems OK
Ebay saw manual
/ Old McCULLOCH Needs Some Attention #6
I had that same saw. I put a 20 inch bar on it and it worked fine. I paid $115 bucks for it in 1978. Good luck with the saw.
/ Old McCULLOCH Needs Some Attention #7
That is the model that broke McCullach.
No shop wants to repair them.
It was cheaper than your cheapee.
Other than changing the chain or starter cord and plug, don't spend any $$ on it.
My opinion.
/ Old McCULLOCH Needs Some Attention #8
I had that same saw. I bought it used back in 1973, ran it for over 15 years, I forgot to put oil in the gas. I never had a problem other than breaking the starter ropes. Great saw. Here's some info on your saw.
Model: Pro-Mac 10-10
MANUFACTURED BY:
McCULLOCH MOTORS CORP.
LOS ANGELES, CALIFORNIA, U.S.A.
SERIES OR ASSEMBLY NUMBER:
600014, codes A,B,C,E,F,G,K,U serial prefix 11, 12
YEAR INTRODUCED:
1977
YEAR DISCONTINUED:
1982
ENGINE DISPLACEMENT:
3.3 cu. in. (54 cc)
NUMBER OF CYLINDERS:
1
CYLINDER BORE:
1.750 in.
PISTON STROKE:
1.375 in.
CYLINDER TYPE:
Aluminum with cast iron sleeve
INTAKE METHOD:
Piston ported
MANUFACTURER ADVERTISED H.P.:
not advertised
WEIGHT :
15.6 lbs. (7.1 kg) powerhead only
OPERATOR CONFIGURATION:
One Man operation
HANDLEBAR SYSTEM:
Rigid
CHAIN BRAKE:
Optional
CLUTCH:
Centrifugal
DRIVE TYPE:
Direct
CONSTRUCTION:
Die cast magnesium
MAGNETO TYPE:
McCulloch flywheel breaker point system. Electronic ignition on units with serial prefix 12
CARBURETOR:
Walbro SDC type
MAJOR REPAIR KIT:
K10-SDC
MINOR REPAIR KIT:
D10-SDC
AIR FILTER SYSTEM:
Flocked wire screen
STARTER TYPE:
McCulloch automatic rewind on left side
OIL PUMP:
Automatic with manual override
OPERATING RPM:
IGNITION TIMING:
26 degrees before TDC
BREAKER POINT SETTING:
0.019 in. (0.48 mm)
FLYWHEEL/COIL AIR GAP:
0.011 to 0.015 in. (0.3 to 0.4 mm)
SPARK PLUG TYPE:
AC CS45T or AC CS42T
SPARK PLUG GAP:
0.025 in. (0.63 mm)
CRANKSHAFT MAIN BEARINGS:
Ball and caged needle roller
FUEL TANK CAPACITY:
1.5 U.S. Pints (710 ml)
FUEL OIL RATIO:
20:1
RECOMMENDED FUEL OCTANE:
Regular
MIX OIL SPECIFICATION:
McCulloch two-cycle chain saw mix oil
CHAIN PITCH:
3/8 in.
CHAIN TYPE:
McCulloch
BAR MOUNT PATTERN:
11 link
SHORTEST GUIDE BAR SUPPLIED:
16 in. (40 cm)
LONGEST GUIDE BAR SUPPLIED:
28 in. (71 cm)
COLOUR SCHEME:
McCulloch Yellow enamel with Black Starter housing
PAINT CODES:
ILLUSTRATED PARTS LIST:
SERVICE MANUAL:
COMMENTS:
/ Old McCULLOCH Needs Some Attention #9
Got one just like it. Good powerful saw but heavy. Will wear you out if you use it all day. Mine is 30 years old and still perfect. Came with a 16" bar & chain , changed it to 20" years ago. I would not hesitate to put a 24" bar & chain on it if I needed one that big. Saw has plenty of power to pull it. I have an Owners Manual I'll be glad to copy and mail you if you want , just PM me. The manual does not give HP or any other specs , no parts list either , but would think any good small engine / chainsaw shop could help with parts particulars. Manual does have some maint. tips , carb adjusting , etc.
/ Old McCULLOCH Needs Some Attention #10
I've got two of them that run and two more that are salvage. I don't think you'll find new parts anywhere. They are screamers when they're tuned right and have a very cool distinctive exhaust note, and yes they'll definitely pull a 20" 3/8 chain.
My advice is to look for a salvage unit(s) on ebay for parts. I've never had much trouble with the fuel system but the pull rope assembly is a poor design on the model you have with the chain brake, so if you buy a parts donor look for a '71+ with the chain brake assembly.
/ Old McCULLOCH Needs Some Attention #11
Mine has a 20" bar. Once I get it started (usually have to use starting fluid) it will cut like crazy! Got tired of messing with it and got a new saw. 20 some years old.
/ Old McCULLOCH Needs Some Attention #12
54cc, at least by today's standards, makes it a fairly big saw. I think my Husky 55 is only 40-some cc's and it's pretty strong.
I used earlier model Mac saws than this one and always had pretty good luck with them, but as another poster pointed out, chainsaws are just about a throw-away commodity any more. Unless there is sentimental or nostalgic value to be had, you're better off investing in a new saw. $150 2006 dollars will buy what took $300 or more back in the day.
Ah, those were the days. Mac's and Homelite XL-12's.
43018CFL (A59228)
43018CFL (A59228)
Towable Road Crossing / Pipe Bridge Trailer (A63689)
Towable Road...
2017 Kia Cadenza Sedan (A61574)
2017 Kia Cadenza...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A61572)
2025 GIYI GY-PG72C...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
