Old McCULLOCH Needs Some Attention
   / Old McCULLOCH Needs Some Attention #1
AL_Josh
Mobile, Alabama
Cub LT 1046, 2000 Honda Rancher, 2004 Carolina Skiff
I was at my grandmother's house today and asked if I could get this saw to run. It was my grandfathers. It has sat in her shed for probly 15 to 20 years. It is a McCULLOCH PRO MAC 10-10.
I cleaned the spark plug and looked it over. I saw the fuel pick-up line had dried on it and I needed to get it out of the tank and after messing with it awhile I finally got it out. I then cleaned the tank out good and aded fuel. The line from the tank to the carb was still in decent shape. Anyway I got it to run and it ran like a top as long as I held the bar up and the fuel could get to the line.
So where can I buy a fuel line kit for it? I remember my grandfather replacing it when I was little. I have another saw but, I would like to get this running.
Also can anyone tell me anything about it? (Size Engine, Hp, anything like that) It appears to be a well built saw. I see no plastic on it except the chain brake.
Thanks to all,
Josh
Pic # 2
Pic #3
Sorry, Also How long of a bar could I use on it? I have a 16" on my cheapo saw. So I would like to use with a longer bar.
Thanks again,
Josh
   / Old McCULLOCH Needs Some Attention #5
Here's a link to a manual for sale on Ebay, the auction ends today but the price seems OK
Ebay saw manual
   / Old McCULLOCH Needs Some Attention #6
I had that same saw. I put a 20 inch bar on it and it worked fine. I paid $115 bucks for it in 1978. Good luck with the saw.
   / Old McCULLOCH Needs Some Attention #7
That is the model that broke McCullach.
No shop wants to repair them.
It was cheaper than your cheapee.
Other than changing the chain or starter cord and plug, don't spend any $$ on it.
My opinion.
   / Old McCULLOCH Needs Some Attention #8
I had that same saw. I bought it used back in 1973, ran it for over 15 years, I forgot to put oil in the gas. I never had a problem other than breaking the starter ropes. Great saw. Here's some info on your saw.
Model: Pro-Mac 10-10
MANUFACTURED BY:
McCULLOCH MOTORS CORP.
LOS ANGELES, CALIFORNIA, U.S.A.
SERIES OR ASSEMBLY NUMBER:
600014, codes A,B,C,E,F,G,K,U serial prefix 11, 12
YEAR INTRODUCED:
1977
YEAR DISCONTINUED:
1982
ENGINE DISPLACEMENT:
3.3 cu. in. (54 cc)
NUMBER OF CYLINDERS:
1
CYLINDER BORE:
1.750 in.
PISTON STROKE:
1.375 in.
CYLINDER TYPE:
Aluminum with cast iron sleeve
INTAKE METHOD:
Piston ported
MANUFACTURER ADVERTISED H.P.:
not advertised
WEIGHT :
15.6 lbs. (7.1 kg) powerhead only
OPERATOR CONFIGURATION:
One Man operation
HANDLEBAR SYSTEM:
Rigid
CHAIN BRAKE:
Optional
CLUTCH:
Centrifugal
DRIVE TYPE:
Direct
CONSTRUCTION:
Die cast magnesium
MAGNETO TYPE:
McCulloch flywheel breaker point system. Electronic ignition on units with serial prefix 12
CARBURETOR:
Walbro SDC type
MAJOR REPAIR KIT:
K10-SDC
MINOR REPAIR KIT:
D10-SDC
AIR FILTER SYSTEM:
Flocked wire screen
STARTER TYPE:
McCulloch automatic rewind on left side
OIL PUMP:
Automatic with manual override
OPERATING RPM:
IGNITION TIMING:
26 degrees before TDC
BREAKER POINT SETTING:
0.019 in. (0.48 mm)
FLYWHEEL/COIL AIR GAP:
0.011 to 0.015 in. (0.3 to 0.4 mm)
SPARK PLUG TYPE:
AC CS45T or AC CS42T
SPARK PLUG GAP:
0.025 in. (0.63 mm)
CRANKSHAFT MAIN BEARINGS:
Ball and caged needle roller
FUEL TANK CAPACITY:
1.5 U.S. Pints (710 ml)
FUEL OIL RATIO:
20:1
RECOMMENDED FUEL OCTANE:
Regular
MIX OIL SPECIFICATION:
McCulloch two-cycle chain saw mix oil
CHAIN PITCH:
3/8 in.
CHAIN TYPE:
McCulloch
BAR MOUNT PATTERN:
11 link
SHORTEST GUIDE BAR SUPPLIED:
16 in. (40 cm)
LONGEST GUIDE BAR SUPPLIED:
28 in. (71 cm)
COLOUR SCHEME:
McCulloch Yellow enamel with Black Starter housing
PAINT CODES:
ILLUSTRATED PARTS LIST:
SERVICE MANUAL:
COMMENTS:
   / Old McCULLOCH Needs Some Attention #9
Got one just like it. Good powerful saw but heavy. Will wear you out if you use it all day. Mine is 30 years old and still perfect. Came with a 16" bar & chain , changed it to 20" years ago. I would not hesitate to put a 24" bar & chain on it if I needed one that big. Saw has plenty of power to pull it. I have an Owners Manual I'll be glad to copy and mail you if you want , just PM me. The manual does not give HP or any other specs , no parts list either , but would think any good small engine / chainsaw shop could help with parts particulars. Manual does have some maint. tips , carb adjusting , etc.
   / Old McCULLOCH Needs Some Attention #10
I've got two of them that run and two more that are salvage. I don't think you'll find new parts anywhere. They are screamers when they're tuned right and have a very cool distinctive exhaust note, and yes they'll definitely pull a 20" 3/8 chain.
My advice is to look for a salvage unit(s) on ebay for parts. I've never had much trouble with the fuel system but the pull rope assembly is a poor design on the model you have with the chain brake, so if you buy a parts donor look for a '71+ with the chain brake assembly.
2007 Ford Focus Hatchback (A54815)
2007 Ford Focus...
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
2018 Ford Fusion Hybird Sedan (A53424)
2018 Ford Fusion...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
2012 Ford F-550 4x4 Chipper Truck (A52377)
2012 Ford F-550...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
