Old kubota B6100-d needs help
   / Old kubota B6100-d needs help #1
Barney6595
Grants Pass, Oregon
kubota B6100-D
Kubota B6100 - Looking for the 2 rear axles used okay,
also 3 point hydrolics raise ok but won't hold and bleed of immediately. Is this a hard fix like the clutch was?
   / Old kubota B6100-d needs help #2
Good luck on finding parts. You 'bleed off' is the rockshaft piston ring that is failed.
Thank You, I'll look that up, I do have the old original owners manual.
   / Old kubota B6100-d needs help #4
You'll need a shop manual for that I suspect. On the older Kubota units, the rockshaft casting and internal piston and linkage come off from the top of the gearcase. Not a big job but parts may be an issue.
thanks, I was looking at the diagram and wondering where the entry point was. Looks like there are a couple of o-rings and a seal in there. it would be nice to get rear hydrolics working. Right now I use the Manual method - ratch strap come-along to adjust hieght.
2021 PETERBILT 389 MID-ROOF SLEEPER (A52472)
2021 PETERBILT 389...
2011 GMC Acadia SLE SUV (A50324)
2011 GMC Acadia...
2007 International 7600 Tandem Truck, VIN # 1HSWYAHR37J478209 (A51572)
2007 International...
2017 Buick Regal Sedan (A50324)
2017 Buick Regal...
2002 Fleetwood Expedition 36ft Motorhome (A51694)
2002 Fleetwood...
2019 Infiniti QX60 SUV (A50324)
2019 Infiniti QX60...
