Old kubota B6100-d needs help
   / Old kubota B6100-d needs help #1
Barney6595
Grants Pass, Oregon
kubota B6100-D
Kubota B6100 - Looking for the 2 rear axles used okay,
also 3 point hydrolics raise ok but won't hold and bleed of immediately. Is this a hard fix like the clutch was?
   / Old kubota B6100-d needs help #2
Good luck on finding parts. You 'bleed off' is the rockshaft piston ring that is failed.
Thank You, I'll look that up, I do have the old original owners manual.
   / Old kubota B6100-d needs help #4
You'll need a shop manual for that I suspect. On the older Kubota units, the rockshaft casting and internal piston and linkage come off from the top of the gearcase. Not a big job but parts may be an issue.
thanks, I was looking at the diagram and wondering where the entry point was. Looks like there are a couple of o-rings and a seal in there. it would be nice to get rear hydrolics working. Right now I use the Manual method - ratch strap come-along to adjust hieght.
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
2015 Peterbilt 320 Truck (A51692)
2015 Peterbilt 320...
