old impliments contaminating the system?
/ old impliments contaminating the system? #1
Kendrick
Vermont
DK45S(Cab)
I am getting a mower/conditioner ready for use. The impliment came with the property. I have no idea what treatement it has had prevously and dont trust any fluid that may be in it currently. I suspect it was run on a ollie 1850 but not sure.
any suggestions of whether im being over parinoid on my new tractors behalf or is there somthing I should do before hooking up the hydro lines? the bailer is 100% pto. thoug if i could only find a kicker for cheep ;)
/ old impliments contaminating the system? #2
I would flush out the old implement. Fluid is cheap, the guts in your tractor -- not cheap.
jb
/ old impliments contaminating the system? #3
I know a guy who rents a tractor to flush all of his new purchases. I don't agree with it, just know it happens.
I got a lift cylinder of unknown fluid condition. I went ahead and powered it up, using the fluid from my tractor. Then I blocked it up with a good jack, removed the hose, took the end off the hose in a 55 gallon drum and then released the jack so the weight compressed the cylinder. I got to see all of the contaminates of the cylinder. Mine was actually pretty clean, so I topped off the tractor and put it to work.
David from jax
/ old impliments contaminating the system? #4
Ditto waht the others said.. not too hard to purge the cyl and represssurize it a few times.. If it is DA.. just do both sides, one at a time.
No.. you are not being over paranoid... The pumps on my tractor cost about 2 paychecks... and I got to eat during those 2 weeks.. thus.. i gotta keep the oil cean..
Soundguy
2005 JOHN DEERE 672D MOTOR GRADER (A67714)
2005 JOHN DEERE...
2015 Yamaha 350hp 4-Stroke Outboard Boat Motor (A66738)
2015 Yamaha 350hp...
20t Ton Air/Manual Hydraulic Bottle Jack (A64557)
20t Ton Air/Manual...
CATERPILLAR PAVER (A65053)
CATERPILLAR PAVER...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2015 CATERPILLAR D6T LGP HIGH TRACK CRAWLER DOZER (A65056)
2015 CATERPILLAR...
