Old house electrical question.
   / Old house electrical question. #31
Anyway, here is what I've done so far, probably ineffective but the best I could do. I bought some 2-to-3 prong adapters. For my computer I ran 14 ga wound copper from the ground on the plug adapter to a large cold water copper supply pipe. For the tiny window unit upstairs I ran the same type of wire out the window to a metal stake in the ground. Not sure if I've accomplished anything but that's the extent of what I've done.
A better solution would be to run the ground wire back to the panel and tie it in on the bus bar with the other ground conductors. That way you are certain that the ground is at the same potential. I wouldn't trust the plumbing in an old house to be properly bonded or even to all be galvanized or copper.
Or have a licensed electrician run new wire for the air conditioner etc.
   / Old house electrical question. #32
N80,
I'm new to the forum but I live and work in central SC as a Facilities Engineering Supervisor. If you are in or around the Columbia area, I may be able to help you out by either recommending some good electricians or lending a hand myself when I have some free time from the granddaughters.
   / Old house electrical question. #33
I'd be shocked if replacing all the electric service is not the way to go. Problem isn't so much the electrical, but the damage you will do to the house in the process. Still, its worth doing. Things are probably require more juice in the future, not less
   / Old house electrical question. #34
...Problem isn't so much the electrical, but the damage you will do to the house in the process...
That's the gospel truth right there. Running wires is the easy part.
   / Old house electrical question. #35
Especially on older homes. Mine being of chimney type construction, circa 1920, we fished from the crawl space and the attic. I ran new wire to all the old outlets. Added a few new outlets too.
Course I had the roof off the house, but that is another story. :)
   / Old house electrical question. #36
Yeah. The only reason mine is practical to re-wire right now is because I have the basement all torn apart. I'm only doing the outlets that I can get to from the basement.
   / Old house electrical question. #37
The OP did say there was a newer panel. The time consuming part can be trying to not damage the whole house replacing wiring.:thumbsup:
   / Old house electrical question. #38
I wouldn't trust the new panel till it was looked at b a good electrician. I've seen some impressive hodge podges, and even downright fraud (6" of romex from outlets, spliced in the wall to knob and tube. Nice.)
Thanks guys. Been away for a few days without internet access. I've got an electrician coming over in a couple of days to help us get by for the next few months. There are several outlets (added 15-20 years ago) for window units. They have to receptacles for old window units. I'm going to see if he can rewire them for standard three prong outlets for my newer window units. I'll ask him about some of the other grounding issues.
After spending some time in the basement looking at that mess (hodge-podge is spot on) and realizing that the bedrooms upstairs only have one outlet each I'm leaning towards all new wiring. Originally I was just planning on new wiring in the kitchen which will be gutted and the master bath and laundry which will be a new addition. But I think I'll be happier with a complete re-do.
James, I appreciate the offer but as mentioned I'll be having an electrician by in a few days anyway. I grew up in Columbia by the way. Still have family there.
   / Old house electrical question. #40
... But I think I'll be happier with a complete re-do...
Safer!
I am sure you marvelled at some of the discoveries you have made - visually.
Can you imagine what you may not uncover if you do not go about the complete way?
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58216)
2008 MOTIV...
New/Unused AGT Industrial 70-inch Seeder (A57454)
New/Unused AGT...
2012 Kenworth T660 T/A Sleeper Cab Truck Tractor (A55973)
2012 Kenworth T660...
2006 Ford F-750 Hazardous Material Truck (A56858)
2006 Ford F-750...
Toro Greensmaster 3150 Commercial Reel Mower (A56857)
Toro Greensmaster...
2025 JMR 66in Single Cylinder Brush Grapple Skid Steer Attachment (A56857)
2025 JMR 66in...
