Old Grease
   / Old Grease #1
First one
Eastbrook, ME.
08' Kubota L3240 HST /cab
Just to get a diff. veiw on this . The old man I talked to when greaseing the backhoe the other day said don't worry about the old grease that's around the grease fittings and around the pins where the old grease pushes out. But the new foreman wants all the old grease removed so there's no old grease to be seen around the pins . Is he just being a clean freak, or what?
Scott
   / Old Grease #2
I'm inclined to say yes. It seems to me that the old grease helps to keep dirt out of the joints.
   / Old Grease #3
Hello
Removing the old grease will not only get rid of the grit and grime but it will make it easier to see when it is properly greased.
   / Old Grease #4
It sounds like you have the best sort of foreman you can get: The kind that won't give you grief so long as you're tidying up. ;)
There's something to be said for being a neat freak...to a degree. There's always that balance between the extreme attitudes of, "if a machine is being cleaned, then it's not working," and putting so much importance on keeping things clean that it becomes busy-work that gets in the way of real production.
It's nice to have clean equipment for a few reasons: Personal pride, company image, to make things nicer for your servicemen... just push it as being green by preventing old grease from getting into the environment.
If operators are over-greasing the machines, things can get really messy. I swear that some guys go through as much grease as fuel! By the way, guys, I'm trusting that there are no hyperbole policemen on the forum.....
   / Old Grease #5
How does he want the old grease removed?
Not that I am going to leap into it, but I have a lot of places where there is old grease has built up quite a bit and am thinking of how to get it off.
So far my thoughts are running toward a pressure washer out in the far corner of the property, followed by a good session of re-greasing.
   / Old Grease #6
I don't remove old grease, It does help in keeping out dirt&dust. Removing the old grease does make the machine look better and cuts down on the likelihood of a piece of grease dropping off and someone stepping on it and carrying it into a home or something like that. So if you're in a location where looks or cleanliness is important I can see removing the old grease.
But for every day folks (as long as you don't over grease making a mess) leaving the old grease, IMHO is good.
David
   / Old Grease #7
I use old cardboard scraps as scrapers to get the worst off; disposable nitrile gloves are your friend. On one bad job, I started by putting gloves on and scooping handfuls into a bucket. I swear I pulled a gallon of grease of a nasty, little excavator once (Cat 311, if I recall).
@CurlyDave: Please don't just hose it down in the back 40. In a perfect world, you'd be able to clean it on a concrete pad that drained into a separator. That's not always possible but you can try to limit the harm done. I wouldn't want to see that on anybody's land.
I was on one site where the machines were parked in a low spot for pressure washing. It was a horrible mixture of grease and mud that's going to be a remediation nightmare.
How about walking/trailering your machine to the nearest self-serve car wash? Been there and done that to do the preliminary cleaning of components for reman jobs. :)
As for cleaning machines off, I did a fair bit when I started my apprenticeship. I usually started with a fire hose to knock the worst off; especially for dry mud in track undercarriages....hose, hack with shovel, repeat. The hose is much more effective on heavy stuff than a pressure washer.
For dealing with grease using a pressure washer, a model with a boiler is a must...along with a caustic cleaner. With things like booms, start at the base, and work outwards. You might find yourself just pushing grease around rather than blowing it off, so just push it all to the end and deal with it there.
The most frustrating thing to clean besides the base of an excavator boom, is the centre pivot of an articulated loader: You spray one side...which pushes the grease to the other side. You walk around to spray that side, and push it back to the first side. It gets a little better each time around and you go back and forth until it gets to an acceptable level.
Oh, and put on some raingear that you don't care about and don't need for anything else.
   / Old Grease #8
First thing our PM mecanics used to do on the Macks was take a putty knife and chunk of cardboard and scrape the excess grease off the 5th wheel coupler and remove the differential 'breathers' and front wheel oil seal fill plugs & toss them in the parts washer b/4 going around cleaning the pushed out grease off the steering and suspension components and clean each grease fitting. Then they would grease the truck wiping the excess off.
They never got grease on the door handle or steering wheel!
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2025 Auger Skid Steer Attachment (A53421)
2025 Auger Skid...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A54811)
2024 Wanco...
Advance SC750 28in Floor Scrubber (A53421)
Advance SC750 28in...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
