Old Ford Tractors Engine Interchangeability
   / Old Ford Tractors Engine Interchangeability #11
Thanks for your input Chris. My thinking is it's probably going to be a pain trying to get the BP valve lined up just right to make it operational with the NAA top cover.
I'll Probably go with a stand pipe off the test port with a valve and rig up an angle iron triangle for the top link rocker down to the lower three point arms. Or TOH 8n top cover modification and add a diverter valve.
Being cooped up inside this winter I just wonder what will work and what won't. Because of no heat in the barn and cold temps I haven't done much but push snow and prep for the next snow storm . Looks like about 8" of fresh stuff and it;s still snowing.
Kirk
   / Old Ford Tractors Engine Interchangeability #12
the top cover mod is really, really simple... 2 tapped holes and a plug.. only one needs to be drilled even.
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
SELLICK S80 STRAIGHT MAST FORKLIFT (A51242)
SELLICK S80...
2005 GEHL CTL70 TURBO SKID STEER (A51242)
2005 GEHL CTL70...
2007 Peterbilt 378 Semi (A50514)
2007 Peterbilt 378...
Ih 4300 Field Cultivator (A50514)
Ih 4300 Field...
MESSAGE BOARD W/ LETTERS (A51244)
MESSAGE BOARD W/...
