Old Ford Flail mower rebuild
/ Old Ford Flail mower rebuild #1
BobReeves
Platinum Member
Tulsa OK
Ford 3000
Neighbor has an old Ford Flail mower sitting out in a field. I asked him about it and he said go ahead and haul it over to your place and see what you can do with it. Walked over and took a look, it has a plate that says Ford but the model is blank. Has a serial number to long to remember and another number 22-124.. The belt is off the pulleys but the idler pulley looks fairly new. Gear box turns and feels good. Neighbor said he thinks he put new blades on it but it was banging against the housing once in a while so he quit using it. The housing needs quite a bit of work but a little plate steel and welding should take care of that pretty quick.
Going to be a couple days before I can get it over here but was wondering if anyone has any experience with these things and might give me a few hints on what to look for when I get into rebuilding it.
/ Old Ford Flail mower rebuild #2
No experience in working on them (yet), but I have a JD siting in the yard. They aren't bush hogs, so don't try to make one out of it. I mow the church yard with mine because it is too big for my small yard. It does a wonderful job on that field behind the church.
Good luck wiht yours,
Happy tinkering,
David from jax
/ Old Ford Flail mower rebuild #3
Bob,
Good luck with the rebuild. If you need parts, I would check out Flail Master. They had all the parts for my father's old Mott mower when it needed some rebuilding.
Flail Master
Russ
2002 CATERPILLAR 963C CRAWLER LOADER (A65053)
2002 CATERPILLAR...
2011 Jeep Grand Cherokee Laredo SUV (A61574)
2011 Jeep Grand...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2014 Chevrolet Silverado Pickup Truck (A62613)
2014 Chevrolet...
2018 MACK PINNACLE (A65643)
2018 MACK PINNACLE...
