Old disker - question
/ Old disker - question #1
5stljayhawks
'71 MF 135
I'm a rookie.
Have access to an old disk 4"-6" sunk in the ground. On the front end(?) there is a saw blade looking thing, thinking adjusts the depth of the blades. Is this correct? On the back there is straight 1" pin hitch, is this for towing or adding addition disks, or something else?
I have pics if need requested.
/ Old disker - question #2
I'm sure you will get a quick response once you post photos.
/ Old disker - question #3
If there is a lever involved with the sawtooth thing then it will be to change the angle of the disks.
The hitch on back is more than likely for a set of harrows.:D
/ Old disker - question #4
The hitch at the back would be for a Drag or a EZ Flow spreader of some sort? Ken Sweet
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
2025 Auger Bit Skid Steer Attachment (A64553)
2025 Auger Bit...
213065 (A64276)
213065 (A64276)
Case 2090 Tractor (A66285)
Case 2090 Tractor...
LOT OF YETTER SHARK TOOTH TRASH WHEEL UNIT MOUNTED (A64278)
LOT OF YETTER...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
